Tom's Hardware > Forum > Graphic & Displays > Nvidia > Question about running crysis on very high setting
Forum Graphic & Displays : Nvidia - Question about running crysis on very high setting
im building my high end pc but i want to play crysis at very high setting.
im wondering if this card http://www.newegg.com/Product/Prod [...] 6814133243
can run at the frame rate of the NVIDIA Geforce 8800 GT 1024 MB in SLI
or what is the best card or best cards that's around 300$ that can run crysis in high setting
http://www.tomshardware.com/charts [...] 1,757.html
Sponsored Links
The two cards are not that differant, one would run pretty much the same as the other (single card for single card),
You need to define High Settings, Res, Detail,AA/AF etc
Mactronix
Reply to mactronix
If you want to play Crysis at very high settings with any stability, start with a 285GTX and work from there. Anything less has almost no hope with Very High settings.
Reply to gamerk316
why is the 8800gt sli run a better frame rate then all the other 9800s
Reply to obelisk282
- -1 +
8800GT = 9800GT. After that, it depends on the clocks manufactures used.
I point out, the 8800/9800GT is a good card, but is getting on at this point, and simply doesn't have the muscle for a game like Crysis.
Reply to gamerk316
Im playing crysis (the original) everything on very high 1920x1440 no AA@approx 45-50 fps (by fraps) with the cards at 750/1512/1100 (gtx 260 sli)
Message edited by teamlosigp on 02-18-2009 at 05:46:11 AM
Reply to teamlosigp
not true I have amd athlon 64 dual core with 3 gig of memory and a zotac geforce 9800gt over clock ddr3 512 pci-e 2.0 and have crysis on very high and works perfectly, no problems at all, runs smooth. I think my card does better than my ATI hdcard.
Reply to travismontana
Ok first 8800GT's in SLI work beautifully as far as scaling is concerned and this is mainly down to the maturity of the drivers, remember the card has been around for a while now so you would hope they would have it right by now. And by the way i wouldnt go as far as fanboy but i prefer ATI
@ travismontana
You dont mention which athlon 64 dual core or what your screen res etc is and you also dont mention which ATI card you are talking about. As such your statement dosent actually mean anything.
Care to elabourate :)
Mactronix
Reply to mactronix
hmmm dont know about that, in dx9 hacked to very high except with physics, textures and object quality on high, with the natural mod, my 4870 handles it just fine at 1400x900. Oc'd to 800/1050 2xaa is playable with 30fps average, and my subsytem is a bit poo too (e6300@2.8ghz, 3gb ram, xp 32, sluggish 250gb hdd). 1600x1200 with a fast subsystem and a moderately oc'd 4870 1gb or stock gtx216 would do dx9 v.high very very well. What benchmarking sites dont explain is the hit very high physics, textures and choosing dx10 over dx9 makes on average fps. a gtx 285 would be overkill for anything less than 1900x1200.
Reply to spoonboy
For one my friend has geforce 9800gt and it runs crysis a solid 40 to 60 fps at very high everything
Reply to Anonymous
This topic again.
Well, my 4870x2 runs it at very high, 19x12 with 4xAA. Playable at least to me (30fps avg). However, I rarely go past the entrance to the alien ship if I was to replay it so take that for what you will.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
- 0 +
strangestranger wrote :
This topic again.
Really? My pair of 4870x2s is only playable at 19x12 with 2xAA to me, with some sections playable at 4x (when I had a single one, it wasn't playable with any AA, though it could do 19x12 very high just fine). Maybe I'm just pickier than you are...
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
Really, as I say I haven't played through it in a wee while bar a run through with the A.I set to ignore till the last section so I could finish it due to a memory leak in my other saved game.
What sort of fps do you get with 4x AA? I can't recall my own getting less than 25fps unless I shook the mouse violently side to side.
- 0 +
At 4x, it drops as low as 20 in some places, which I find too slow. At 2x, it stays 30+ everywhere, and 40+ in most places. It's playable at 4x in most places, but (especially in the snow region, IIRC) it's under 30fps in a few spots.
Reply to cjl
Hmm, don't notice it myself. Must just be me, never have been a 60+fps kind of person.
There are 797 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
