Tom's Hardware > Forum > Home Theatre > Satellite TV > 2 x receivers + 1 motor, how the hell do i do this ?
Forum Home Theatre : Satellite TV - 2 x receivers + 1 motor, how the hell do i do this ?
Archived from groups: alt.satellite,alt.satellite.internet,alt.satellite.tv,alt.satellite.tv.europe,alt.usenet.satellite (More info?)
I have a humax receiver, everything works fine (i can find all the
satelites)
Now i have a second receiver (dreambox), when i store the position in this
receiver, my humax lose the positions.
Who can help me with this ? I read many forums but never about this problem.
What kind information you must know to give me a answer ?
thanks,
Nicolai.
Sponsored Links
Hmmm dont think that is possible with 2 diff rcvrs. Not totally sure though,
im sure the pulse count would be diff from one rcvr to another hence you
lossing on one rcvr. I assume you have a dual c-band lnbf and trying to
control the arm with both rcvrs?
If i remember right u have to go back to the original position you started
from then use the other rcvr. Do you have some sort of control box on tha
actuator arm as to stop the voltage entering the other rcvr?
"Nicolai Admiraal" <nicolai.admiraal@hetnet.nl> wrote in message
news:ccpl99$g9i$1@reader10.wxs.nl...
> satelites)
problem.
> thanks,
> Nicolai.
Reply to Vin
You should use only one of the receivers to move the dish.
Digibox problem? : A reboot solves 90% of these.
The Sky Digital FAQ: http://tinyurl.com/yvnsy
How to get UK TV overseas: http://tinyurl.com/6p73
Fed up with logos / red buttons? : http://logofreetv.org/
BBC gone? : http://www.astra2d.co.uk/
Only the truth as I see it.
No monies return'd. ;-)
Reply to Anonymous
Use one receiver as dish mover and loop the second receiver output through
the first one typically by putting output of second receiver into ant input
of first one and using remote to change signal source
I do this with three of mine, satcruiser controls coship3188C and 4DTV
controls it and satcruiser
> satelites)
problem.
> thanks,
> Nicolai.
Reply to Anonymous
you have the dish controlled by diseqc, the receivers dont' actually move
the dish but sends commands like "goto sat n. xx", and there's no feedback,
the dish don't say "i'm on sat xx".
once you understand this you know that before using a receiver you must let
it issue a command, this may involve to move to a random sat temporarily
eg. box is on sat A, dish on sat B = no signal
so move to B, C... and then A
> satelites)
problem.
> thanks,
> Nicolai.
Reply to Anonymous
There are 1048 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
