I'm building a system using an Intel DX58SO motherboard, Ultra X3 850 watt PSU and Saphire Radeon HD 3870 graphics card. There are a total of four possible power connections on the motherboard and one on the graphics card. Before I power the system up, I want to make sure that I've got the power connection correct...
From the PSU to the Motherbaord I have the 2x12-pin power connection, and the 2x4 PCIe power connection.
From the PSU to the graphics adapter I have the 2x6 pin connector on the graphics card connnected.
That leaves two additional connectors on the motherboard:
1. A 4-pin molex type connector (i.e. what you used to find on disk drives and the like)
2. A SATA style power connector (lableled "aux power" on the board)
The motherboard documentation is not clear about whether I need to connect these to the PSU for my configuration, nor is it clear about which output of the PSU they should be connected to (i.e. 5V, 12V etc). All the manual says is that one of these needs to be connected if I have a PCIe card that draws greater than 75 watts. Any help would be appreciated.
thanks.
thanks.
