Crosshair IV Formula and 212+ heat sink question
i plan on getting the crosshair IV formula mobo with a 1090t in it
i plan on getting the CM 212+ to cool it
I was wondering if the push pull config with the fans would get in the way of my ram
i would be using the G.SKILL Flare 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000)
also if you suggest any other ram/ cpu heatsink i would be open to new, better ideas in that area.
Thanks much
P.S have a full tower case
Thanks much
Here is some ram, it will work on that board according to asus :)
Ask the community
