Archived from groups: alt.satellite.tv (More info?)
Becuase of problems in reception, I'm trying to get a hold of the information of
which transponders are on which of the 3 main DirecTV satellites AND which
channels are carried on which of the transponder frequencies.
I've asked DirecTV. They don't know. The only solutions they offer is to send
someone out (not sure if HE would know, either, these guys just aim the dishes
and test for transponder strength).
I'd love to find out the information on these transponders and a list of which
channels come from which so that I could 'see' the pattern in which channels
lose their signals at what times.
Also of interest would be to know HOW some of these are broadcast; for instance,
local channels may be 'aimed' at a given region, hence a stronger signal there.
Any knowledge of such information would be appreciated
Since it makes no difference which channels are carried on which
transponders you won't be getting that information from DirecTV - the
channels are compressed together based upon a lot of variables and change
transponders as needed due to capacity issues.
If your dish is aimed properly at 101 degrees you will get at least 90 on
all the transponders you need to see. The local channels are on spot beams
so you receive only the locals for your area based on where you are.
All the main services are on the 101 bird. Secondary services are on the
119 degree bird with the remainder on 110 degrees. A three feed wide dish
that is aimed properly will get enough signal on all three birds so as not
to cause reception losses. If you have trouble with the signal going away
you need the dish aimed properly or perhaps relocated to a better location.
The signal should not go away on a clear day.
"Stellijer" <howapropos@hotmail.nospam.com> wrote in message
news:llkJc.1000$vD6.308@bignews1.bellsouth.net...
information of
send
dishes
which
channels
instance,
there.
Hello and thanks again for the info.
As for a "properly aimed dish getting at least 90 on all the transponders", I
get over 90 on some, down to 40 on others, and 0 on some. Naturally, this
cannot all be ascribed to an improperly aimed dish.
I agree the dish may need to be relocated; I'm afraid the installer may have
placed it in a location where tree growth would occlude the 'bird' at 101. The
curiosity is why some transponders are *SO* much stronger than others. Hence
why I wanted that data; to figure out WHY I have the discrepancy. An improperly
aimed dish may receive signals better from an ENTIRELY different location but a
vast discrepancy of signals from the same location in space makes one wonder.
I have gotten SOME of this information and some makes sense. For instance, some
of my "0" level transponders carry channels I'm not getting at all. (I got a
'map' of which channels are on which transponders). But it looks like I have 2
distinct questions:
1. Why are some transponders so weak while others are quite strong? To my
knowledge I get nothing from the 110&119 sats
2. Why are some of my odd numbered channels now not coming in AT ALL?
I don't know if these problems have the same cause. There may be a technical
problem which has to do with odd-numbered transponders... and at the same time
the weak signals come from occlusion.
thesatguy <jdolan1@houston.rr.com> wrote in message
news:CVlJc.43474$mY2.19987@fe1.texas.rr.com...
> information of
> send
> dishes
> which
> channels
> instance,
> there.
sounds like your lnbf is bad
that would explain the various signal levels - if you get 90s on some then
the others would not be lower than say 85 or just a tad lower - you will get
0 on those on spot beams you cannot see.
news:LeoJc.5499$PF4.3772@bignews4.bellsouth.net...
transponders", I
have
The
Hence
improperly
but a
wonder.
instance, some
got a
have 2
> distinct questions:
my
technical
time
change
on
beams
the
dish
not
away
location.
> > information of
which
is to
> > send
the
> > dishes
of
> > which
> > channels
> > instance,
signal
> > there.
What, exactly, is "LNBF"? I understand that dishes are either single of dual
"LNB", and that the term referes to the reception mechanism, but I'm not sure
what the components are. I also don't know what the "F" would mean (or if
you're referring to the mechanism in the dish which receives or the mechanism in
the receiver which 'decodes').
I understand the physics and mechanics of broadcast and reception, in general,
fairly well, but I'm far from expert at the circuitry in sat systems
Yes, I agree that I shouldn't get lower than around 85 or so on some
transponders if it was alignment or occlusion of the signal by a branch. Yet,
as I said, I get 95-98 on a couple of them, 60s on others and as low as 40 on
some others and then 0 on a bunch of them.
Why would I not see these spot beams? What in the LNBF would do this? Could it
be the wiring, too?
J
news:QNwJc.32629$857.7322@fe2.texas.rr.com...
> transponders", I
> have
> The
> Hence
> improperly
> but a
> wonder.
> instance, some
> got a
> have 2
> > distinct questions:
> my
> technical
> time
> change
> on
> beams
> the
> dish
> not
> away
> location.
> > > information of
> which
> is to
> > > send
> the
> > > dishes
> of
> > > which
> > > channels
> > > instance,
> signal
> > > there.
In the interim since my last reply an hour or so ago, I tried something.
I just HAPPENED to have a spare dish from someone who demolished a structure. I
tried swapping out the little LNB from the spare dish to my main dish and
hooking up the lead to the similar connector (the one cable was connected to the
connector on thr right, if you're looking at the connectors on the LNB - I don't
know if it matters).
I unplugged the received for a while then when plugging it back in I got the
exact same kinds of levels including the zeros on the odd transponders.
Should I suspect the receiver itself?
> transponders", I
> have
> The
> Hence
> improperly
> but a
> wonder.
> instance, some
> got a
> have 2
> > distinct questions:
> my
> technical
> time
> change
> on
> beams
> the
> dish
> not
> away
> location.
> > > information of
> which
> is to
> > > send
> the
> > > dishes
> of
> > > which
> > > channels
> > > instance,
> signal
> > > there.
news:gYwJc.7070$PF4.1741@bignews4.bellsouth.net...
dual
sure
mechanism in
general,
Yet,
on
Could it
> be the wiring, too?
> J
LNBF is the same thing as LNB.
If you have a dealer nearby, take it in and have it checked. Most of them
don't charge for this.
It's not the receiver!,... If your receiving only odd, or even transponders
then you have a cabling/connection problem. Make sure all your cabling is
RG-6! Some people on this group will tell you RG-59 will suffice. WRONG!
Another common problem is using a CATV splitter. It won't handle the mHz
frequency and will cancel-out a "side" (which refers to your odd/even
transponders).
Another common problem is faulty connectors, (F connectors installed with
either shielding or strands coming into contact with the core, or not making
contact with the connector (bad crimp).
FYI:
DirecTV USA at 101.0°W
February 1, 2004
CHANNEL ORDER
TRANSPONDER ORDER
CH
Channel Name
TP
CH
Channel Name
TP
80
CBS-HD New York
8
107
Blockbuster Ticket PPV
CBS-HD Los Angeles
16
111
CBS-HD Customer Information
9
112
DTV PPV Previews
13
114
DirecTV Sports PPV
21
116
DirecTV Freeview Events Series
25
160
PPV Info & Events
11
168
27
180
Directors Theatre PPV
Lifetime Movie Network
24
317
QVC US
29
595
Playboy TV
The Hot Zone
NESN - New England Sports Net
USA Network
24
256
TCM - Turner Classic Movies
A&E - Arts & Entertainment
Discovery Channel
5
290
The Disney Channel East
Cartoon Network
8
325
Spike TV
29
327
CMT - Country Music Channel
CNBC
27
362
The Weather Channel
16
526
Encore East
23
811
® R & B & Hip Hop
27
812
® Rap
23
828
® Today's Country
23
841
® Blues
8
117
32
201
Customer News
DirecTV Adult PPV
27
224
TV Guide
Infomercial Channel
Sale PPV
23
350
C-SPAN
Special PPV
7
366
Newsworld International
Special PPV
16
368
FIT TV
Special PPV
7
596
Spice Platinum
DTV PPV Previews
11
601
NBA TV
Customer News
5
202
CNN USA
ESPNews
5
203
Court TV
25
208
ESPN Classic
5
204
CNN Headline News
Food Network US
5
206
ESPN
SoapNet
5
207
ESPNews
5
299
Nickelodeon East
5
208
ESPN Classic
5
301
TV Land
5
209
ESPN 2
29
520
Starz! East
5
212
NFL Network
19
523
Black Starz!
5
218
Order MEGA MAR MAD'S here!
29
550
IFC US
5
219
DIRECTV Channel
Outdoor Channel
5
220
DIRECTV Sports Schedule
21
626
Empire Sports Network
5
222
DTV Customer Info
16
809
® Classic R & B
5
224
TV Guide
® Soundscapes
5
227
Infomercial Channel
® Smooth Jazz
5
228
Gem Shopping Network
7
840
® Jazz
5
229
HGTV US
15
860
® Classic R&B
5
230
DIY - Do It Yourself Network
17
458
JA3-TV (NBC - Jackson)
6
231
Food Network US
5
459
JA12-TV (CBS - Jackson)
6
232
Fine Living
29
460
JA16-TV (ABC - Jackson)
6
234
Shop At Home
30
461
JA27-TV (UPN - Jackson)
6
236
E! Entertainment TV
9
462
JA29-TV (PBS - Jackson)
6
239
Celebrity Shopping Network
9
463
JA40-TV (WB - Jackson)
6
240
HSN - Home Shopping Network
13
464
JA35-TV (FOX - Jackson)
6
242
USA Network
SP3-TV (ABC - Shreveport)
6
243
America's Store
19
480
SP6-TV (NBC - Shreveport)
6
244
Sci-Fi
19
481
SP12-TV (CBS - Shreveport)
6
245
TNT
SP24-TV (PBS - Shreveport)
6
246
Fight Satellite Taxes
9
483
SP33-TV (FOX - Shreveport)
6
247
TBS Superstation
SP45-TV (UPN - Shreveport)
6
248
FX
15
190
Special PPV
7
249
Comedy Central
17
195
Special PPV
7
251
Oxygen TV Network
11
228
7
252
Lifetime
9
271
The History Channel Int'l
7
253
Nicktoons
7
254
AMC - American Movie Classics
19
309
GSN - Game Show Network
7
255
Pax TV
9
333
MTV 2
7
256
Galavisión US
7
258
Fox Movie Channel
27
530
Mystery
7
260
WE - Women's Entertainment
9
533
WAM!
7
262
SoapNet
5
597
The Hot Network
7
264
BBC America
25
622
YES Network
7
265
Fox Sports New York
7
266
The Biography Channel
11
802
® Showcase 1
7
269
The History Channel
27
816
® Metal
7
271
7
817
® Alternative Rock
7
273
Bravo US
29
820
® Progressive/Adult Alternative
7
276
National Geographic Channel
25
80
CBS-HD New York
8
277
Travel Channel
29
122
8
278
Discovery Channel
8
279
Discovery Health
13
942
LA9-TV (IND - Los Angeles)
8
280
TLC - The Learning Channel
17
976
HN48-TV (TEL - Houston)
8
282
Animal Planet
11
998
DIRECTV Pricing and Packaging
8
284
Discovery Science Channel
19
82
9
285
Discovery Times Channel
19
236
E! Entertainment TV
9
286
Discovery Home & Leisure
27
239
9
287
Discovery Wings Channel
15
246
9
290
Lifetime
9
291
The Disney Channel West
23
255
Pax TV
9
292
Toon Disney
11
260
9
294
Discovery Kids
21
531
True Stories
9
295
PBS Kids
19
532
Action
9
296
Cartoon Network
The Golf Channel
9
297
Boomerang
11
630
Fox Sports South
9
298
Nick Noggin
21
647
Fox Sports Midwest
9
299
Nickelodeon East
5
815
® Power Rock
9
300
Nickelodeon West
21
851
® Tejano
9
301
TV Land
5
856
® Power Rock
9
302
Nicktoons
7
857
® Party Favorites
9
307
WGN Superstation (Chicago)
11
858
® Soft Album Mix
9
309
7
864
® Tejano
9
311
ABC Family
CNN USA
Hallmark Channel US
21
204
CNN Headline News
TRIO
13
206
ESPN
QVC US
DIRECTV Channel
World Harvest Television
13
245
TNT
Spike TV
TBS Superstation
ABC Family
BET - Black Entertainment TV
15
380
NY2-TV (CBS - New York)
MTV
11
382
NY4-TV (NBC - New York)
MTV 2
7
384
PBS X
VH 1
25
386
NY7-TV (ABC - New York)
VH 1 Classic
27
388
NY5-TV (FOX - New York)
FUSE
25
500
DTV Movies and Sports This Week
Direct Shopping Network (00-06)
25
819
® Classic Rock
C-SPAN
® Hit List
C-SPAN 2
25
823
® 80's
Bloomberg TV US
27
824
® 70's
Tech TV
25
880
CNBC
MSNBC
23
882
CNBC World
25
883
CNN Financial Network (Mon-Fri)
15
105
PPV Info & Events
11
358
CNN International (Sat-Sun)
15
200
DTV PPV Previews
11
360
Fox News Channel
27
251
Oxygen TV Network
11
362
The Weather Channel
11
366
Animal Planet
11
367
ACN Jewelry Television
21
292
Toon Disney
11
368
FIT TV
Boomerang
11
369
Daystar TV
13
307
11
370
ShopNBC
13
331
MTV
11
371
The Church Channel
11
371
The Church Channel
11
372
TBN - Trinity Broadcasting Net
19
402
Univisión
11
373
The Word
19
628
Fox Sports Pittsburgh
11
375
WorldLink TV
17
652
Fox Sports West
11
377
PBS You
17
653
Fox Sports West 2
11
380
DTV PPV Previews
13
381
LA2-TV (CBS - Los Angeles)
22
240
13
382
Discovery Health
13
383
LA4-TV (NBC - Los Angeles)
22
315
TRIO
13
384
PBS X
13
386
Daystar TV
13
387
LA7-TV (ABC - Los Angeles)
22
370
ShopNBC
13
388
Love Stories
13
389
LA11-TV (FOX - Los Angeles)
22
593
Adult Special Offer
13
398
LA Broadcast Center
17
594
ATOS - A Taste of Spice
13
402
Univisión
11
613
Fox Sports World
13
404
Galavisión US
7
637
Fox Sports Ohio Cleveland
13
440
TU3-TV (TFT - Tucson)
22
814
® New Wave
13
441
TU4-TV (NBC - Tucson)
22
821
® Soft Rock
13
442
TU6-TV (PBS - Tucson)
22
825
® Solid Gold Oldies
13
443
TU9-TV (ABC - Tucson)
22
850
® Mexicana
13
444
TU11-TV (FOX - Tucson)
22
861
® Mexicana
13
445
TU13-TV (CBS - Tucson)
22
465
WB16-TV (ABC - Wilkes-Barre)
14
446
TU18-TV (UPN - Tucson)
22
466
WB22-TV (CBS - Wilkes-Barre)
14
448
TU58-TV (WB - Tucson)
22
467
WB28-TV (NBC - Wilkes-Barre)
14
458
6
468
WB38-TV (WB - Wilkes-Barre)
14
459
6
469
WB44-TV (PBS - Wilkes-Barre)
14
460
6
470
WB56-TV (FOX - Wilkes-Barre)
14
461
6
472
DM5-TV (ABC - Des Moines)
14
462
6
473
DM8-TV (CBS - Des Moines)
14
463
6
474
DM11-TV (PBS - Des Moines)
14
464
6
475
DM13-TV (NBC - Des Moines)
14
465
14
476
DM17-TV (FOX - Des Moines)
14
466
14
477
DM23-TV (WB - Des Moines)
14
467
14
229
HGTV US
15
468
14
248
FX
15
469
14
287
15
470
14
329
15
472
14
358
15
473
14
358
15
474
14
521
Starz! West
15
475
14
527
Encore West
15
476
14
529
Westerns
15
477
14
620
Fox Sports New England
15
479
6
632
Sunshine Network
15
480
6
806
® Sounds of the Season
15
481
6
829
® Classic Country
15
482
6
833
® Easy Listening
15
483
6
842
® Gospel
15
484
6
81
CBS-HD Los Angeles
16
500
16
501
HBO East
32
191
Special PPV
16
502
HBO Plus East
30
222
DTV Customer Info
16
503
HBO Signature
32
940
LA5-TV (WB - Los Angeles)
16
504
HBO West
32
999
Local Channel Information
16
505
HBO Plus West
30
230
17
507
HBO Family East
30
249
Comedy Central
17
508
HBO Family West
30
280
17
512
Cinemax East
30
375
WorldLink TV
17
513
MoreMax
32
377
PBS You
17
514
Cinemax West
32
398
LA Broadcast Center
17
520
Starz! East
5
522
Starz! Theater East
17
521
Starz! West
15
607
Speed Channel
17
522
Starz! Theater East
17
641
Fox Sports North
17
523
Black Starz!
5
649
Fox Sports Arizona
17
526
Encore East
® Rock
17
527
Encore West
15
826
® Bluegrass
17
528
Love Stories
13
830
® Big Band & Swing
17
529
Westerns
15
831
® Singers & Standards
17
530
Mystery
7
212
NFL Network
19
531
True Stories
9
243
America's Store
19
532
Action
9
244
Sci-Fi
19
533
WAM!
7
254
19
537
Showtime East
32
284
19
538
Showtime Too
32
285
19
539
Showtime Showcase
32
295
PBS Kids
19
540
Showtime West
32
372
19
542
Showtime Extreme
30
373
The Word
19
544
The Movie Channel East
30
612
Fuel
19
545
The Movie Channel West
30
638
Fox Sports Ohio Cincinnati
19
547
Flix
30
834
® Classical Masterpieces
19
549
Sundance Channel
30
836
® Light Classical
19
550
IFC US
5
843
® Contemporary Christian
19
580
DIRECTV Free Concert
25
863
® Taste of Italy
19
593
Adult Special Offer
13
101
DirecTV Sports PPV
21
594
13
220
21
595
Playboy TV
Discovery Kids
21
596
Spice Platinum
Nick Noggin
21
597
The Hot Network
7
300
Nickelodeon West
21
598
The Hot Zone
Hallmark Channel US
21
600
DirecTV Sports Schedule
21
367
21
601
NBA TV
21
602
TVG Horse Racing
27
604
DirecTV Sports PPV
21
604
DirecTV Sports PPV
21
634
Fox Sports Florida
21
605
The Golf Channel
9
645
Fox Sports Rocky Mountain
21
606
Outdoor Channel
5
753
21
607
Speed Channel
17
813
® Dance
21
608
Outdoor Life Network
23
865
® Contemporary Instrumentals
21
610
College Sports TV
29
381
22
612
Fuel
19
383
22
613
Fox Sports World
13
387
22
620
15
389
22
621
MSG Network
23
440
22
622
YES Network
7
441
22
623
22
624
Fox Sports New York
7
443
22
626
5
444
22
628
11
445
22
629
Comcast SportsNet MidAtlantic
23
446
22
630
Fox Sports South
9
448
22
631
Turner South
24
938
22
632
Sunshine Network
15
939
22
634
Fox Sports Florida
21
941
22
636
Fox Sports Detroit
27
943
22
637
13
135
23
638
19
140
23
639
Fox Sports Chicago
27
142
23
641
Fox Sports North
17
183
Sale PPV
23
643
Fox Sports Southwest
25
291
23
645
21
356
MSNBC
23
647
Fox Sports Midwest
9
608
23
649
Fox Sports Arizona
17
621
MSG Network
23
651
Fox Sports Northwest
23
629
23
652
Fox Sports West
11
651
23
653
Fox Sports West 2
11
654
Fox Sports Bay Area
23
654
Fox Sports Bay Area
23
808
® Reggae
23
658
RN5-TV (WB - Roanoke)
31
810
® Smooth R & B
23
659
RN7-TV (CBS - Roanoke)
31
827
® Americana
23
660
RN10-TV (NBC - Roanoke)
31
832
® Show Tunes
23
661
RN13-TV (ABC - Roanoke)
31
108
24
662
RN15-TV (PBS - Roanoke)
31
115
24
663
RN24-TV (UPN - Roanoke)
31
631
Turner South
24
664
RN27-TV (FOX - Roanoke)
31
667
LO3-TV (NBC - Louisville)
24
667
24
668
LO11-TV (ABC - Louisville)
24
668
24
669
LO15-TV (PBS - Louisville)
24
669
24
671
LO32-TV (CBS - Louisville)
24
671
24
672
LO34-TV (WB - Louisville)
24
672
24
673
LO41-TV (FOX - Louisville)
24
673
24
674
LO58-TV (UPN - Louisville)
24
674
24
675
LO68-TV (PBS - Louisville)
24
675
24
103
25
701-719
NFL SUNDAY TICKET
203
Court TV
25
718-720
English Premier League Soccer
264
BBC America
25
721-734
NBA League Pass
276
25
735-739
NCAA Mega March Madness
335
VH 1
25
740-752
NHL Center Ice
339
FUSE
25
753
21
340
25
754-769
MLB Extra Innings
351
C-SPAN 2
25
770-779
ESPN Game Plan
354
Tech TV
25
780-793
ESPN Full Court
357
CNBC World
25
794-799
MLS/ESPN Shootout
580
25
801
DirecTV Free Concert
25
643
25
802
® Showcase 1
7
801
25
806
15
106
27
808
® Reggae
23
130
27
809
® Classic R & B
5
138
27
810
® Smooth R & B
23
171
DirecTV Adult PPV
27
811
® R & B & Hip Hop
Fox Movie Channel
27
812
® Rap
The History Channel
27
813
® Dance
21
286
27
814
® New Wave
13
337
VH 1 Classic
27
815
® Power Rock
9
353
Bloomberg TV US
27
816
® Metal
7
360
Fox News Channel
27
817
® Alternative Rock
7
602
TVG Horse Racing
27
818
® Rock
17
636
Fox Sports Detroit
27
819
® Classic Rock
Fox Sports Chicago
27
820
7
109
29
821
® Soft Rock
13
124
29
822
® Hit List
ESPN 2
29
823
® 80's
29
824
® 70's
Fine Living
29
825
® Solid Gold Oldies
13
273
Bravo US
29
826
® Bluegrass
17
277
Travel Channel
29
827
® Americana
23
610
College Sports TV
29
828
® Today's Country
Shop At Home
30
829
® Classic Country
15
502
HBO Plus East
30
830
® Big Band & Swing
17
505
HBO Plus West
30
831
17
507
HBO Family East
30
832
® Show Tunes
23
508
HBO Family West
30
833
® Easy Listening
15
512
Cinemax East
30
834
19
542
Showtime Extreme
30
836
® Light Classical
19
544
30
838
® Soundscapes
5
545
30
839
® Smooth Jazz
5
547
Flix
30
840
® Jazz
5
549
Sundance Channel
30
841
® Blues
31
842
® Gospel
15
659
31
843
19
660
31
850
® Mexicana
13
661
31
851
® Tejano
9
662
31
856
® Power Rock
9
663
31
857
® Party Favorites
9
664
31
858
® Soft Album Mix
9
873
RC6-TV (CBS - Richmond)
31
860
® Classic R&B
5
874
RC8-TV (ABC - Richmond)
31
861
® Mexicana
13
875
RC12-TV (NBC - Richmond)
31
863
® Taste of Italy
19
876
RC23-TV (PBS - Richmond)
31
864
® Tejano
9
877
RC35-TV (FOX - Richmond)
31
865
21
878
RC57-TV (PBS - Richmond)
31
873
31
879
RC65-TV (UPN - Richmond)
31
874
31
170
32
875
31
501
HBO East
32
876
31
503
HBO Signature
32
877
31
504
HBO West
32
878
31
513
MoreMax
32
879
31
514
Cinemax West
32
880
Showtime East
32
881
Showtime Too
32
882
Showtime Showcase
32
883
Showtime West
32
938
22
701-719
NFL SUNDAY TICKET
939
22
718-720
940
16
721-734
NBA League Pass
941
22
735-739
942
8
740-752
NHL Center Ice
943
22
754-769
MLB Extra Innings
976
8
770-779
ESPN Game Plan
998
8
780-793
ESPN Full Court
999
16
794-799
MLS/ESPN Shootout
See my replies in the other thread on this. According to Directv tech
support the most important transponders are 1 & 2. Set transponder to the
weakest of 1 or 2, then re-aim dish to get best signal.
I'm not claiming cable is not a problem, but if you have dropouts on some
channels try this technique.
> transponders then you have a cabling/connection problem. Make sure all
> your cabling is RG-6! Some people on this group will tell you RG-59 will
> suffice. WRONG!
> transponders).
> making contact with the connector (bad crimp).
> FYI:
> February 1, 2004
> CHANNEL ORDER
> TRANSPONDER ORDER
> CH
> Channel Name
> TP
> CH
> Channel Name
> TP
> 80
> CBS-HD New York
> 8
> 107
> 1
> 81
> CBS-HD Los Angeles
> 16
> 111
> 1
> 82
> 9
> 112
> 1
> 100
> DTV PPV Previews
> 13
> 114
> 1
> 101
> DirecTV Sports PPV
> 21
> 116
> 1
> 103
> 25
> 160
> 1
> 105
> PPV Info & Events
> 11
> 168
> 1
> 106
> 27
> 180
> 1
> 107
> 1
> 253
> 1
> 108
> 24
> 317
> QVC US
> 1
> 109
> 29
> 595
> Playboy TV
> 1
> 111
> 1
> 598
> The Hot Zone
> 1
> 112
> 1
> 623
> 1
> 114
> 1
> 242
> USA Network
> 2
> 115
> 24
> 256
> 2
> 116
> 1
> 265
> 2
> 117
> 3
> 278
> Discovery Channel
> 2
> 118
> 5
> 290
> 2
> 121
> 3
> 296
> Cartoon Network
> 2
> 122
> 8
> 325
> Spike TV
> 2
> 124
> 29
> 327
> 2
> 125
> 3
> 355
> CNBC
> 2
> 130
> 27
> 362
> The Weather Channel
> 2
> 134
> 16
> 526
> Encore East
> 2
> 135
> 23
> 811
> ® R & B & Hip Hop
> 2
> 138
> 27
> 812
> ® Rap
> 2
> 140
> 23
> 828
> ® Today's Country
> 2
> 142
> 23
> 841
> ® Blues
> 2
> 145
> 8
> 117
> 3
> 151
> 3
> 121
> 3
> 152
> 3
> 125
> 3
> 160
> 1
> 151
> 3
> 168
> 1
> 152
> 3
> 170
> 32
> 201
> Customer News
> 3
> 171
> DirecTV Adult PPV
> 27
> 224
> TV Guide
> 3
> 180
> 1
> 227
> Infomercial Channel
> 3
> 183
> Sale PPV
> 23
> 350
> C-SPAN
> 3
> 190
> Special PPV
> 7
> 366
> 3
> 191
> Special PPV
> 16
> 368
> FIT TV
> 3
> 195
> Special PPV
> 7
> 596
> Spice Platinum
> 3
> 200
> DTV PPV Previews
> 11
> 601
> NBA TV
> 3
> 201
> Customer News
> 3
> 118
> 5
> 202
> CNN USA
> 10
> 207
> ESPNews
> 5
> 203
> Court TV
> 25
> 208
> ESPN Classic
> 5
> 204
> CNN Headline News
> 10
> 231
> Food Network US
> 5
> 206
> ESPN
> 10
> 262
> SoapNet
> 5
> 207
> ESPNews
> 5
> 299
> Nickelodeon East
> 5
> 208
> ESPN Classic
> 5
> 301
> TV Land
> 5
> 209
> ESPN 2
> 29
> 520
> Starz! East
> 5
> 212
> NFL Network
> 19
> 523
> Black Starz!
> 5
> 218
> 29
> 550
> IFC US
> 5
> 219
> DIRECTV Channel
> 10
> 606
> Outdoor Channel
> 5
> 220
> 21
> 626
> 5
> 222
> DTV Customer Info
> 16
> 809
> ® Classic R & B
> 5
> 224
> TV Guide
> 3
> 838
> ® Soundscapes
> 5
> 227
> Infomercial Channel
> 3
> 839
> ® Smooth Jazz
> 5
> 228
> 7
> 840
> ® Jazz
> 5
> 229
> HGTV US
> 15
> 860
> ® Classic R&B
> 5
> 230
> 17
> 458
> 6
> 231
> Food Network US
> 5
> 459
> 6
> 232
> Fine Living
> 29
> 460
> 6
> 234
> Shop At Home
> 30
> 461
> 6
> 236
> E! Entertainment TV
> 9
> 462
> 6
> 239
> 9
> 463
> 6
> 240
> 13
> 464
> 6
> 242
> USA Network
> 2
> 479
> 6
> 243
> America's Store
> 19
> 480
> 6
> 244
> Sci-Fi
> 19
> 481
> 6
> 245
> TNT
> 10
> 482
> 6
> 246
> 9
> 483
> 6
> 247
> TBS Superstation
> 10
> 484
> 6
> 248
> FX
> 15
> 190
> Special PPV
> 7
> 249
> Comedy Central
> 17
> 195
> Special PPV
> 7
> 251
> Oxygen TV Network
> 11
> 228
> 7
> 252
> Lifetime
> 9
> 271
> 7
> 253
> 1
> 302
> Nicktoons
> 7
> 254
> 19
> 309
> 7
> 255
> Pax TV
> 9
> 333
> MTV 2
> 7
> 256
> 2
> 404
> Galavisión US
> 7
> 258
> Fox Movie Channel
> 27
> 530
> Mystery
> 7
> 260
> 9
> 533
> WAM!
> 7
> 262
> SoapNet
> 5
> 597
> The Hot Network
> 7
> 264
> BBC America
> 25
> 622
> YES Network
> 7
> 265
> 2
> 624
> Fox Sports New York
> 7
> 266
> 11
> 802
> ® Showcase 1
> 7
> 269
> The History Channel
> 27
> 816
> ® Metal
> 7
> 271
> 7
> 817
> ® Alternative Rock
> 7
> 273
> Bravo US
> 29
> 820
> 7
> 276
> 25
> 80
> CBS-HD New York
> 8
> 277
> Travel Channel
> 29
> 122
> 8
> 278
> Discovery Channel
> 2
> 145
> 8
> 279
> Discovery Health
> 13
> 942
> 8
> 280
> 17
> 976
> 8
> 282
> Animal Planet
> 11
> 998
> 8
> 284
> 19
> 82
> 9
> 285
> 19
> 236
> E! Entertainment TV
> 9
> 286
> 27
> 239
> 9
> 287
> 15
> 246
> 9
> 290
> 2
> 252
> Lifetime
> 9
> 291
> 23
> 255
> Pax TV
> 9
> 292
> Toon Disney
> 11
> 260
> 9
> 294
> Discovery Kids
> 21
> 531
> True Stories
> 9
> 295
> PBS Kids
> 19
> 532
> Action
> 9
> 296
> Cartoon Network
> 2
> 605
> The Golf Channel
> 9
> 297
> Boomerang
> 11
> 630
> Fox Sports South
> 9
> 298
> Nick Noggin
> 21
> 647
> Fox Sports Midwest
> 9
> 299
> Nickelodeon East
> 5
> 815
> ® Power Rock
> 9
> 300
> Nickelodeon West
> 21
> 851
> ® Tejano
> 9
> 301
> TV Land
> 5
> 856
> ® Power Rock
> 9
> 302
> Nicktoons
> 7
> 857
> ® Party Favorites
> 9
> 307
> 11
> 858
> ® Soft Album Mix
> 9
> 309
> 7
> 864
> ® Tejano
> 9
> 311
> ABC Family
> 10
> 202
> CNN USA
> 10
> 312
> Hallmark Channel US
> 21
> 204
> CNN Headline News
> 10
> 315
> TRIO
> 13
> 206
> ESPN
> 10
> 317
> QVC US
> 1
> 219
> DIRECTV Channel
> 10
> 321
> 13
> 245
> TNT
> 10
> 325
> Spike TV
> 2
> 247
> TBS Superstation
> 10
> 327
> 2
> 311
> ABC Family
> 10
> 329
> 15
> 380
> 10
> 331
> MTV
> 11
> 382
> 10
> 333
> MTV 2
> 7
> 384
> PBS X
> 10
> 335
> VH 1
> 25
> 386
> 10
> 337
> VH 1 Classic
> 27
> 388
> 10
> 339
> FUSE
> 25
> 500
> 10
> 340
> 25
> 819
> ® Classic Rock
> 10
> 350
> C-SPAN
> 3
> 822
> ® Hit List
> 10
> 351
> C-SPAN 2
> 25
> 823
> ® 80's
> 10
> 353
> Bloomberg TV US
> 27
> 824
> ® 70's
> 10
> 354
> Tech TV
> 25
> 880
> 10
> 355
> CNBC
> 2
> 881
> 10
> 356
> MSNBC
> 23
> 882
> 10
> 357
> CNBC World
> 25
> 883
> 10
> 358
> 15
> 105
> PPV Info & Events
> 11
> 358
> 15
> 200
> DTV PPV Previews
> 11
> 360
> Fox News Channel
> 27
> 251
> Oxygen TV Network
> 11
> 362
> The Weather Channel
> 2
> 266
> 11
> 366
> 3
> 282
> Animal Planet
> 11
> 367
> 21
> 292
> Toon Disney
> 11
> 368
> FIT TV
> 3
> 297
> Boomerang
> 11
> 369
> Daystar TV
> 13
> 307
> 11
> 370
> ShopNBC
> 13
> 331
> MTV
> 11
> 371
> The Church Channel
> 11
> 371
> The Church Channel
> 11
> 372
> 19
> 402
> Univisión
> 11
> 373
> The Word
> 19
> 628
> 11
> 375
> WorldLink TV
> 17
> 652
> Fox Sports West
> 11
> 377
> PBS You
> 17
> 653
> Fox Sports West 2
> 11
> 380
> 10
> 100
> DTV PPV Previews
> 13
> 381
> 22
> 240
> 13
> 382
> 10
> 279
> Discovery Health
> 13
> 383
> 22
> 315
> TRIO
> 13
> 384
> PBS X
> 10
> 321
> 13
> 386
> 10
> 369
> Daystar TV
> 13
> 387
> 22
> 370
> ShopNBC
> 13
> 388
> 10
> 528
> Love Stories
> 13
> 389
> 22
> 593
> Adult Special Offer
> 13
> 398
> LA Broadcast Center
> 17
> 594
> 13
> 402
> Univisión
> 11
> 613
> Fox Sports World
> 13
> 404
> Galavisión US
> 7
> 637
> 13
> 440
> 22
> 814
> ® New Wave
> 13
> 441
> 22
> 821
> ® Soft Rock
> 13
> 442
> 22
> 825
> ® Solid Gold Oldies
> 13
> 443
> 22
> 850
> ® Mexicana
> 13
> 444
> 22
> 861
> ® Mexicana
> 13
> 445
> 22
> 465
> 14
> 446
> 22
> 466
> 14
> 448
> 22
> 467
> 14
> 458
> 6
> 468
> 14
> 459
> 6
> 469
> 14
> 460
> 6
> 470
> 14
> 461
> 6
> 472
> 14
> 462
> 6
> 473
> 14
> 463
> 6
> 474
> 14
> 464
> 6
> 475
> 14
> 465
> 14
> 476
> 14
> 466
> 14
> 477
> 14
> 467
> 14
> 229
> HGTV US
> 15
> 468
> 14
> 248
> FX
> 15
> 469
> 14
> 287
> 15
> 470
> 14
> 329
> 15
> 472
> 14
> 358
> 15
> 473
> 14
> 358
> 15
> 474
> 14
> 521
> Starz! West
> 15
> 475
> 14
> 527
> Encore West
> 15
> 476
> 14
> 529
> Westerns
> 15
> 477
> 14
> 620
> 15
> 479
> 6
> 632
> Sunshine Network
> 15
> 480
> 6
> 806
> 15
> 481
> 6
> 829
> ® Classic Country
> 15
> 482
> 6
> 833
> ® Easy Listening
> 15
> 483
> 6
> 842
> ® Gospel
> 15
> 484
> 6
> 81
> CBS-HD Los Angeles
> 16
> 500
> 10
> 134
> 16
> 501
> HBO East
> 32
> 191
> Special PPV
> 16
> 502
> HBO Plus East
> 30
> 222
> DTV Customer Info
> 16
> 503
> HBO Signature
> 32
> 940
> 16
> 504
> HBO West
> 32
> 999
> 16
> 505
> HBO Plus West
> 30
> 230
> 17
> 507
> HBO Family East
> 30
> 249
> Comedy Central
> 17
> 508
> HBO Family West
> 30
> 280
> 17
> 512
> Cinemax East
> 30
> 375
> WorldLink TV
> 17
> 513
> MoreMax
> 32
> 377
> PBS You
> 17
> 514
> Cinemax West
> 32
> 398
> LA Broadcast Center
> 17
> 520
> Starz! East
> 5
> 522
> Starz! Theater East
> 17
> 521
> Starz! West
> 15
> 607
> Speed Channel
> 17
> 522
> Starz! Theater East
> 17
> 641
> Fox Sports North
> 17
> 523
> Black Starz!
> 5
> 649
> Fox Sports Arizona
> 17
> 526
> Encore East
> 2
> 818
> ® Rock
> 17
> 527
> Encore West
> 15
> 826
> ® Bluegrass
> 17
> 528
> Love Stories
> 13
> 830
> ® Big Band & Swing
> 17
> 529
> Westerns
> 15
> 831
> 17
> 530
> Mystery
> 7
> 212
> NFL Network
> 19
> 531
> True Stories
> 9
> 243
> America's Store
> 19
> 532
> Action
> 9
> 244
> Sci-Fi
> 19
> 533
> WAM!
> 7
> 254
> 19
> 537
> Showtime East
> 32
> 284
> 19
> 538
> Showtime Too
> 32
> 285
> 19
> 539
> Showtime Showcase
> 32
> 295
> PBS Kids
> 19
> 540
> Showtime West
> 32
> 372
> 19
> 542
> Showtime Extreme
> 30
> 373
> The Word
> 19
> 544
> 30
> 612
> Fuel
> 19
> 545
> 30
> 638
> 19
> 547
> Flix
> 30
> 834
> 19
> 549
> Sundance Channel
> 30
> 836
> ® Light Classical
> 19
> 550
> IFC US
> 5
> 843
> 19
> 580
> 25
> 863
> ® Taste of Italy
> 19
> 593
> Adult Special Offer
> 13
> 101
> DirecTV Sports PPV
> 21
> 594
> 13
> 220
> 21
> 595
> Playboy TV
> 1
> 294
> Discovery Kids
> 21
> 596
> Spice Platinum
> 3
> 298
> Nick Noggin
> 21
> 597
> The Hot Network
> 7
> 300
> Nickelodeon West
> 21
> 598
> The Hot Zone
> 1
> 312
> Hallmark Channel US
> 21
> 600
> 21
> 367
> 21
> 601
> NBA TV
> 3
> 600
> 21
> 602
> TVG Horse Racing
> 27
> 604
> DirecTV Sports PPV
> 21
> 604
> DirecTV Sports PPV
> 21
> 634
> Fox Sports Florida
> 21
> 605
> The Golf Channel
> 9
> 645
> 21
> 606
> Outdoor Channel
> 5
> 753
> 21
> 607
> Speed Channel
> 17
> 813
> ® Dance
> 21
> 608
> 23
> 865
> 21
> 610
> College Sports TV
> 29
> 381
> 22
> 612
> Fuel
> 19
> 383
> 22
> 613
> Fox Sports World
> 13
> 387
> 22
> 620
> 15
> 389
> 22
> 621
> MSG Network
> 23
> 440
> 22
> 622
> YES Network
> 7
> 441
> 22
> 623
> 1
> 442
> 22
> 624
> Fox Sports New York
> 7
> 443
> 22
> 626
> 5
> 444
> 22
> 628
> 11
> 445
> 22
> 629
> 23
> 446
> 22
> 630
> Fox Sports South
> 9
> 448
> 22
> 631
> Turner South
> 24
> 938
> 22
> 632
> Sunshine Network
> 15
> 939
> 22
> 634
> Fox Sports Florida
> 21
> 941
> 22
> 636
> Fox Sports Detroit
> 27
> 943
> 22
> 637
> 13
> 135
> 23
> 638
> 19
> 140
> 23
> 639
> Fox Sports Chicago
> 27
> 142
> 23
> 641
> Fox Sports North
> 17
> 183
> Sale PPV
> 23
> 643
> 25
> 291
> 23
> 645
> 21
> 356
> MSNBC
> 23
> 647
> Fox Sports Midwest
> 9
> 608
> 23
> 649
> Fox Sports Arizona
> 17
> 621
> MSG Network
> 23
> 651
> 23
> 629
> 23
> 652
> Fox Sports West
> 11
> 651
> 23
> 653
> Fox Sports West 2
> 11
> 654
> Fox Sports Bay Area
> 23
> 654
> Fox Sports Bay Area
> 23
> 808
> ® Reggae
> 23
> 658
> 31
> 810
> ® Smooth R & B
> 23
> 659
> 31
> 827
> ® Americana
> 23
> 660
> 31
> 832
> ® Show Tunes
> 23
> 661
> 31
> 108
> 24
> 662
> 31
> 115
> 24
> 663
> 31
> 631
> Turner South
> 24
> 664
> 31
> 667
> 24
> 667
> 24
> 668
> 24
> 668
> 24
> 669
> 24
> 669
> 24
> 671
> 24
> 671
> 24
> 672
> 24
> 672
> 24
> 673
> 24
> 673
> 24
> 674
> 24
> 674
> 24
> 675
> 24
> 675
> 24
> 103
> 25
> 701-719
> NFL SUNDAY TICKET
> 203
> Court TV
> 25
> 718-720
> 264
> BBC America
> 25
> 721-734
> NBA League Pass
> 276
> 25
> 735-739
> 335
> VH 1
> 25
> 740-752
> NHL Center Ice
> 339
> FUSE
> 25
> 753
> 21
> 340
> 25
> 754-769
> MLB Extra Innings
> 351
> C-SPAN 2
> 25
> 770-779
> ESPN Game Plan
> 354
> Tech TV
> 25
> 780-793
> ESPN Full Court
> 357
> CNBC World
> 25
> 794-799
> MLS/ESPN Shootout
> 580
> 25
> 801
> 25
> 643
> 25
> 802
> ® Showcase 1
> 7
> 801
> 25
> 806
> 15
> 106
> 27
> 808
> ® Reggae
> 23
> 130
> 27
> 809
> ® Classic R & B
> 5
> 138
> 27
> 810
> ® Smooth R & B
> 23
> 171
> DirecTV Adult PPV
> 27
> 811
> ® R & B & Hip Hop
> 2
> 258
> Fox Movie Channel
> 27
> 812
> ® Rap
> 2
> 269
> The History Channel
> 27
> 813
> ® Dance
> 21
> 286
> 27
> 814
> ® New Wave
> 13
> 337
> VH 1 Classic
> 27
> 815
> ® Power Rock
> 9
> 353
> Bloomberg TV US
> 27
> 816
> ® Metal
> 7
> 360
> Fox News Channel
> 27
> 817
> ® Alternative Rock
> 7
> 602
> TVG Horse Racing
> 27
> 818
> ® Rock
> 17
> 636
> Fox Sports Detroit
> 27
> 819
> ® Classic Rock
> 10
> 639
> Fox Sports Chicago
> 27
> 820
> 7
> 109
> 29
> 821
> ® Soft Rock
> 13
> 124
> 29
> 822
> ® Hit List
> 10
> 209
> ESPN 2
> 29
> 823
> ® 80's
> 10
> 218
> 29
> 824
> ® 70's
> 10
> 232
> Fine Living
> 29
> 825
> ® Solid Gold Oldies
> 13
> 273
> Bravo US
> 29
> 826
> ® Bluegrass
> 17
> 277
> Travel Channel
> 29
> 827
> ® Americana
> 23
> 610
> College Sports TV
> 29
> 828
> ® Today's Country
> 2
> 234
> Shop At Home
> 30
> 829
> ® Classic Country
> 15
> 502
> HBO Plus East
> 30
> 830
> ® Big Band & Swing
> 17
> 505
> HBO Plus West
> 30
> 831
> 17
> 507
> HBO Family East
> 30
> 832
> ® Show Tunes
> 23
> 508
> HBO Family West
> 30
> 833
> ® Easy Listening
> 15
> 512
> Cinemax East
> 30
> 834
> 19
> 542
> Showtime Extreme
> 30
> 836
> ® Light Classical
> 19
> 544
> 30
> 838
> ® Soundscapes
> 5
> 545
> 30
> 839
> ® Smooth Jazz
> 5
> 547
> Flix
> 30
> 840
> ® Jazz
> 5
> 549
> Sundance Channel
> 30
> 841
> ® Blues
> 2
> 658
> 31
> 842
> ® Gospel
> 15
> 659
> 31
> 843
> 19
> 660
> 31
> 850
> ® Mexicana
> 13
> 661
> 31
> 851
> ® Tejano
> 9
> 662
> 31
> 856
> ® Power Rock
> 9
> 663
> 31
> 857
> ® Party Favorites
> 9
> 664
> 31
> 858
> ® Soft Album Mix
> 9
> 873
> 31
> 860
> ® Classic R&B
> 5
> 874
> 31
> 861
> ® Mexicana
> 13
> 875
> 31
> 863
> ® Taste of Italy
> 19
> 876
> 31
> 864
> ® Tejano
> 9
> 877
> 31
> 865
> 21
> 878
> 31
> 873
> 31
> 879
> 31
> 874
> 31
> 170
> 32
> 875
> 31
> 501
> HBO East
> 32
> 876
> 31
> 503
> HBO Signature
> 32
> 877
> 31
> 504
> HBO West
> 32
> 878
> 31
> 513
> MoreMax
> 32
> 879
> 31
> 514
> Cinemax West
> 32
> 880
> 10
> 537
> Showtime East
> 32
> 881
> 10
> 538
> Showtime Too
> 32
> 882
> 10
> 539
> Showtime Showcase
> 32
> 883
> 10
> 540
> Showtime West
> 32
> 938
> 22
> 701-719
> NFL SUNDAY TICKET
> 939
> 22
> 718-720
> 940
> 16
> 721-734
> NBA League Pass
> 941
> 22
> 735-739
> 942
> 8
> 740-752
> NHL Center Ice
> 943
> 22
> 754-769
> MLB Extra Innings
> 976
> 8
> 770-779
> ESPN Game Plan
> 998
> 8
> 780-793
> ESPN Full Court
> 999
> 16
> 794-799
> MLS/ESPN Shootout
On Wed, 14 Jul 2004 20:34:12 -0400, "Stellijer"
<howapropos@hotmail.nospam.com> wrote:
<snip>
Local channels are broadcast on transponders 18 and 26. Ever notice
how their signal value/range is significantly higher than the other
transponders?
Greg
On Thu, 15 Jul 2004 10:55:12 -0400, "Stellijer"
<snip>
Exactly "which" transponders are registering a zero level? FYI,
transponders 4, 12 and 20 are typically at zero.
Greg
There are 924 identified and unidentified users. To see the list of identified users, Click here.
