So i have a i5 750 with the gigabyte P55A ud3 motherboard, a hyper 212 cooler, xfx 5770 and corsair 650 psu.
My ram is only showing up as 9-9-9 24 at 1333 and the ram is rated 7-8-7 24 at 1600 i tried to adjust the setting only to get to 1480 or 1850 there was no 1600 also the volz say 1.65 on newegg but on the manufacturer site says 1.6 there is no 1.65 option only 1.64 or 1.66 as well in the bios, so i just left the settings at auto until figure out how to adjust the proper way.
Here is my ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303&cm_re=g.skill_4_gb-_-20-231-303-_-Product
I also just overclocked my cpu yesturday to 3.7 mhz nothing to crazy the voltz were at 1.36. temps stay around 65 when i run prime95 as well 100% cpu load. so temp seems fine as well. idle 30's
any help would be great.
Here is my ram:
