Hi, I'm new to this forum but have already learned a great deal reading many of the posts, especially the sticky on picking your hardware.
What I'm currently using: Compaq Presario S4020WM with a gig of ram and an XFX Geforce 6200 GPU.
Don't need monitor, keyboard, mouse, speakers or headphones.
Do need an OS and I'm torn on what to use, XP home oem or some version of vista for further ability down the road. After looking at the build maybe the choice will become more clear.
my current cart over at newegg has the following items:
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Intel Pentium E5200 Wolfdale 2.5GHz LGA 775 65W Dual-Core Processor Model BX80571E5200 - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
Item #: N82E16817139005 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
HIS Hightech H485FN512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Item #: N82E16814161259 http://www.newegg.com/Product/Product.aspx?Item=N82E16814161259
G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBPI-B - Retail
Item #: N82E16820231209 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822136074 http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
Pioneer 20X DVD±R DVD Burner Black IDE Model DVR-116DBK - OEM
Item #: N82E16827129023 http://www.newegg.com/Product/Product.aspx?Item=N82E16827129023
Grand total including shipping is around $680.
Had been hoping I could hold this under $600 /including OS but obviously I'm well over.
Several things including the PSU, GPU and MOBO where choosen with the hope of future upgrade to duel HD 4850s in the future and also a better than stock CPU cooler so I can try OCing the E5200 (which from what I have read seems to OC really well.)
Any advice, comments and suggestions are welcomed and needed before I cut loose with this much change. Thanks Todd
