Hi guys,
I've recently built a new system and after all the teething problems I finally have it up and performing.
I've got quite a bad overheating problem with my SLI cofiguration, I have the same mobo and cards (different company) as the $2000 performance pc built buy this site: http://www.tomshardware.co.uk/overclock-cpu-gpu,review-31919.html
I'm using the coolermaster RC-600 case, which is a mid tower and of similar dimensions to the Antec case use for the $2000 build.
I'm about to order some nice new case fans such that I'll have 3x intake @ bottom front, 2x case side and 2x output @ top and rear top.
I'm also going to be purchasing a cpu cooler that should just all the cpu heat out the top of the case.
My question is; does anyone know of a good aftermarket cooling solution that will work with the cards in SLI configuration? Bear in mind that these cards are physically v. close and I'm almost certain it wont fit in any other PCI slot configuration so I need something that adds no extra depth to the cards.
The option I have been looking at is the thermalright spitfire, if I buy the mounting bracket it should be compatible, however I'm unsure as to the ram/pcb cooling and whether it will fit in my case.
Any suggestions would be appreciated.
Kind regards,
Kind regards,
