I have an i7 920 d0 that I'm beginning to liquid cool. I picked up a Thermaltake p500 pump and res (not my first choice for pumps but the price was right). My plan is to use a heatkiller 3.0 over the Apogee XT because it is a higher flow block and will probably increase the life of the p500.
Now I'm trying to decide on a radiator. At the moment I only plan on cooling the CPU mostly because of cost issues. Will a Single 120mm rad be sufficient for my application or should I go for a Dual?
I have a NXZT Tempest case that says a dual rad will mount in the top exhaust fans but it sure looks like that would be a tight squeeze, if any one has any experience with this case I would like to hear it. Otherwise I have no problems mounting it on the back side of the case.
Thanks
Thanks
