After much research I am about to order my first liquid cooling system
Being my first system, any feedback would be appreciated!
I will be putting it in an Antec 1200 (Red Theme) with the following components:
Core i7 930
Asus P6X58D-E
6 Gigabytes of Triple channel GSkill Ripjaw
XFX 5870
2 Western Digital Caviar Blacks in Raid 0
Western Digital Raptor
X-Fi Gamer
Antec 1000w
I want to start by just Liquid cooling the i7 and later on when the warranty for the xfx expires, add a water block to the 5870.
So here is what I have so far:
Swiftech Apogee XT CPU Waterblock
Swiftech MCP655 12v DC Pump - with Speed Controller
EK-Multioption RES X2 - 250 Advanced
Swiftech MCR320-QP Quiet Power 3X120mm - Black
EK High Flow Fittings G 1/4 to 1/2in. ID Barb x 4
Breeze Miniature Hose Clamp 7/16 in. to 25/32 in. X 10
PrimoFlex Pro LRT UV Red Tubing - 1/2in. ID X 3/4in. OD
I am unsure of the coolant I want to add ….. What do you suggest? I think I want to go with the most Non Conductive coolant I can find (being my first liquid cooling build)
Are the gains of adding a motherboard water block? Worth it?
I already have the red fans … How is UV going to play with red lighting? Anything I need to add or change to get the best lighting I can?
What are the best fans for this Rad? (I will be mounting it on the back btw via the radbox
Thanks!!
-Chris
Core i7 930
Asus P6X58D-E
XFX 5870
X-Fi Gamer
Antec 1000w
Thanks!!
-Chris
