OS: Windows 7
MOBO: MSI P45-8D Memory Lover
GRAPHIC: ATI 4830
Mem: 2gb x 2 Corsair Dominator 800
Power: 650w
I tried to turn off SpeedStep from the bios setting through the setup but when I save and exit, it automatically shuts down.
When I try to turn it back on, the fans starts to move for 2 seconds, then turns off again, it repeats that on&off over and over till I unplug the whole power on the computer.
It doesn't even turn on, no beep sound, no nothing, its "about" to turn on then shuts down.
so imagine as you turning on computer, then shuts down immediately after 2 sec.
So, only fan and power led light turns on for a sec then goes down again.
Then after like a second, it turns back on again, then after 2 sec turns off again..
on and on.... till I plug out the power cord.
And I have to reset by taking out the battery from the mobo to put it to default again.
I havnet even touched the OC part of it yet, just trying to turn off SpeedStep.
It's very weird.
I read many forums, but nothing suits my situation, so I'm asking the geniuses here x]
Same thing happened when I tried to disable C1E as well.
So my conclusion? Well, Simple.
Whats the problem? How to fix it? How to make it work? Any Solutions or comments? Suggestions?
PS.
From the forums I read, something similar came up and said it was the CMOS prob.
Not sure on that for my situation, if it is, can you clarify it further.
Thank you very much in advance.
GRAPHIC: ATI 4830
Power: 650w
It's very weird.
PS.
