Tom's Hardware > Forum > Motherboards & Memory > Memory > [Solved] Memory problem?
Forum Motherboards & Memory : Memory - [Solved] Memory problem?
Best answer from cmichael138.
Ok just wondering if someone can check my conclusion that a RAM module is defective.
New build PC using Gigabyte GA-M790FXT-UDP5 Rev 1.0, AMD Phenom II X4 955 Black Edition 3.2GHz, Corsair XMS3 4Gb twinned pair, ATI HD 4350 (stopgap card) and a corsair HX 620W PSU plus seagate HDD and HP DVD drive.
Computer would not POST. Lack of speaker made that difficult to work out. Removed both modules and the machine POSTed with error. One module back in. Machines POSTs and boots. Ran memtest (via Ultimate Boot CD) on module. Passed that battery of tests. Tried RAM module in all slots, all POSTed and booted fine. Removed working RAM and installed the second module on its own - nothing. Will occasionally turn the monitor on but then hang, not displaying POST screen or responding to any input from keyboard. Removed RAM and flashed BIOS to latest F5 version to see if that would help but no joy.
Am thinking I have a defective RAM stick but just wanted to check that I haven't missed something obvious before I go to scan.co.uk for an RMA.
Cheers
Tim
Sounds like an RMA
Sponsored Links
If Stick A will allow boot, alone, in any of four slots, and Stick B will not ==> Stick B is not the same as Stick A lol.
RMA the pair.
Reply to Twoboxer
There are 605 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
