Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will the Thermalright Ultra extreme for i7 fit in a thermaltake spedo advance
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will the Thermalright Ultra extreme for i7 fit in a thermaltake spedo advance
This heatsink is huge and I don't know if it will fit in this case. It's going to be on a asus deluxe v2 mobo. Can someone tell me if the side fan will hit the heatsink?
Sponsored Links
Would you mind posting pics in your case? You can also try measuring the inside space of your case, find the dimensions of the fan and heatsink online, and base your estimate on the data.
Reply to r_manic
The case is 9.1 inches wide. That is wider than a typical case. The ThermalRight Ultra Extreme will fit.
Reply to JohnnyLucky
thanks for the replies guys just wanted to make sure.
Reply to hoang53004989
There are 677 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
