Problem using sata and ide hd
Last response: in Storage
July 29, 2010 4:20:16 PM
so i have a sata hard drive and a sata cdrom and whenever i try to hook up my old IDE harddrive *** doesnt work. i set my sata as my primary drive/first in the boot list thing, but whenever i get to what is normally mobo logo thing - > black screen for ~2 seconds~ - > xp loading screen .. it goes mobo screen - > random jmicron ***(pic below) - > black screen indefinitely
bios pix below
picture of the device config, iv tried setting it as ahci and ide(rlly have no clue wat either does)
iv tried every possible setting combination in that pic
jmicron message
hd list(if it matters)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
is my mobo if it helps
rlly have no clue how to fix this :(
i tried cable select, master, slave , no jumper thing in.. also tried 3 different cables and nothing worked
More about : problem sata ide
July 29, 2010 7:10:21 PM
i came to the realization that the hdd is bad:)
m
l
