Hello Tom's Hardware,
I'm building my first desktop, so I have no existing parts to choose from. This is the build I'm currently leaning towards. It ended up costing more than I wanted, but since I want it to be upgradable in the future, I decided I had to go with the more expensive i7 processor/motherboard/ram...
i7 920 2.66 GHz
Radeon HD 4850 X2 2GB
Foxconn Renaissance LGA 1366 Intel X58 ATX Intel Motherboard
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V PSU
Seagate Barracuda 7200.11 500GB Hard Drive for Windows
Seagate Barracuda 1.5TB Hard Drive for media (I already have 2 full 1TB WD external drives, so I definitely need lots of storage space)
LG disk drive (It will rarely be used)
Full Tower ATX Cooler Master Case
I have two 22-inch 1920x1080 monitors, and I plan to do a lot of gaming on my system. I also plan to use Vista Business 64-bit, which I can get for free through my university.
I do have a few questions:
First of all, how's the power supply? Do I need more wattage? Or can I save money and go with less? Keep in mind I plan to add another graphics card in the future.
Secondly, should I stick with the 4850X2, or should I go with the GTX 285? I can get the 285 for just $15 more, but their benchmarks seem to be almost identical. I hope to Crossfire/SLI another card in the future, so would I get better multi-card performance with the 285 since it's just one GPU instead of two, like the 4850X2?
Thirdly, do I need any additional cooling? I don't plan to overclock right away, although I may look into it in the future...
Fourth, do I need to buy any additional parts to go with OEM hard drives or optical disk drives?
Fifth, how's the build overall? Any suggestions?
Thanks a lot guys!
i7 920 2.66 GHz
Thanks a lot guys!
