Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > 8800GT SLI, PSU problems, need advice
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - 8800GT SLI, PSU problems, need advice
Hi everyone, I just need some advice on a buy
I am currently running a computer with 8800GT in SLI, quad Q6600, 8gb ram, 1 dvd player/burner... Nothing TOO fancy
Anyway, I currently own a RP-650-PCAR which fan died and brought the PSU down a notch. So, it can't perform anymore and when there is a load on the computer (let's say game with nice graphics) my computer gives me a nice BSOD.
All worked fine for the year before tho
So I'll switch the PSU, Now... I am hesitating between a bunch of stuff because I don't know that much about computer hardware and I am seeking advice.
Should I replace it with the same model?
If not, I was looking on TigerDirect and NCIX (yes Canada) and I found those that seemed to be adequate... any advice?
http://www.tigerdirect.com/applica [...] CatId=2036
Or should I buy something totally different.
Thanks in advance
Sponsored Links
Corsair is highly recommended and looks to have a good price. It will suit your system well with power to spare.
Reply to rolli59
- 0 +
I have that Corsair PSU running SLi 8800GT w E8400 and its rock solid. Considering the price difference, definately go with the Corsair.
------------------------------ http://farm4.static.flickr.com/3073/2578392638_2827857d10_o.png
Reply to B-Unit
Corsair has a reputation for high quality power supplies that are very reliable and stable. They consistently earn high marks in technical reviews and comparisons.
Reply to JohnnyLucky
There are 1043 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
