Hi, I have a PT6 Deluxe motherboard. I was in BIOS and when exiting I selected "Load Setup Defaults". When I rebooted, it says " no operating system". I don't know what to do to get back into windows vista. HELP...
make sure bios is set to boot from hd first and then verify that it is booting from the correct hd. It usually defaults to whatever drive is on port one but you can manually select any drive you wish
