Hi all =)
I think this is the right place for this question.
I'm growing seeds/cuttings and I need small wind sources for circulation (to prevent a problem called "damping off" where they get moldy and die).... Computer fans look perfect and are cheap!!
But how can I power these fans?
I mean, is there any way to connect multiple computer fans to a wall outlet?
Sponsored Links
Use teh interwebz to find a resistor that matches your wall socket output and fan operating specs.
------------------------------ Q6600 B3 3.0Ghz @ 1.125v
4850
P5B-D
8Gb 800mhz
Reply to mrmez
Thanks...
But I don't know anything about electronics. More detail plz :)
Reply to mousieee
That's an unusual application for a fan.
You do not want to plug these into a wall outlet. Outlet is AC. Fans are DC.
OK. If you are sure that a 12 volt computer fan (or fans) will move enough air to be useful, here's how I would do it ...
Get a cheap computer PSU. It doesn't need to be a good one. You are not going to load it that heavily. Most 12 cm fans pull around .2 amps. So you can power a lot of fans from even a cheap power supply.
Select your fans. If you are not going to be around much when they are running, select for airflow instead of noise (the two are pretty much inversely proportional).
Plug them into the IDE drive molex connectors. You may need "Y" adapters if you have more fans than connectors.
Now you need a way to turn it on. Simplest low tech way is to use a paperclip to short the green wire on the main PSU connector to one of the black wires (ground) on either side of it. This is a low voltage control lead - no danger of shock.
Only other problem I see is environmental protection. That's up to you.
If you decide to do this, let me know how it goes.
Reply to jsc
best thing to do, find an old power supply for a mobile or something with similar ratings to the fans and use that. At own risk of course...
Reply to mi1ez
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > How to power computer fans
There are 1271 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
