Hey all,
I just changed the motherboard in my build and reinstalled windows. Everything seems to be working ok apart form the fact that when my heatsink goes over a certain RPM it begin to rattle. The heatsink was really tricky to fix to the motherboard because of the Northbridge Heatsink being in the way. In the end I had to place the heatsink on top of the CPU before I fixed the supports to the motherboard.
What do you guys think my problem could be? Either the Heatsink itself is broken/bent in some way or its just not fixed to my board properly???
Thanks
Thanks
