Hi. For few days, friends are telling me, that when i talk, my sound is not clear, that they hear some sort of scratching, tik tik voices when i speak... I made test call on skype, and i noticed that when i talk, this really happens....
So i bought myself a new headphones and same problem...I dont know whats the problem, but i think that problem started when i moved headphones from rear panel to front panel jack....but not sure about that!!!
Im using asus p5kc motherboard and realtek HD audio manager. What seems to cause the problem, im not sure. Tried to move the heapdhones from front to rear panel, and same problem....I also disconnected the front panel cable on motherboard, but cant test, because headhpones wont work on rear then...
Please, i need some help and solutions. TY have a great day.
You can test that easy just move the new mic in the back again and see if it's ok or u get the ticks again. If it's ok it means your front panel conector/cable is damadged or loose and the crackling sound you hear is the static that results from that.
