Maybe someone can make a little more sense of this. For several minutes after start-up, a ticking noise emanates from this rig I built a week ago. The ticking goes away after several minutes and only occurs when the system is cold. If it's been run, turned off, and rebooted several hours later, e.g., there's no noise.
The case has 7 fans including the CPU fan, in addition to which there's the power supply fan. I checked the case fans and the CPU fan -- all appear to be unobstructed. It doesn't appear to be the hard drive.
All of which caused me to suspect the power supply fan, plus the noise seemed to be coming from the bottom of the case, where the PSU is located. (It's impossible to be certain, with all those fans blazing.)
So today I performed the following order of operations:
1. I turned the case on its side and stopped the PSU fan from turning on bootup with a swabless Q-Tip (the exhaust port for the PSU blows out of the bottom).
2. I powered the computer up while it was on its side: no noise.
3. I removed the Q-Tip from the PSU fan grill: the fan wouldn't turn at all.
4. I powerered the computer down at Vista's login screen, waited ten seconds or so and powered back up, this time with nothing obstructing the PSU fan grill. The case was still on its side. The PSU fan resumed spinning normally and there was no noise.
5. I powered the computer down again, and turned the case upright, and powered it back on with nothing obstructing any fans.
6. The ticking sound occurred for maybe ten seconds and went away.
Any thoughts? The specs are below. Thanks in advance.
-- COOLER MASTER RC-690-KKA1-GP Black SECC/ ABS ATX Mid Tower Computer Case Real Power Pro 550W Power Supply
-- ASUS P5Q SE/R LGA 775 Intel P45 ATX Intel Motherboard
-- ASUS EAH4850 TOP/HTDI/512M Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video
-- Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor
-- CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
-- SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe
-- ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
-- SEAGATE Barracuda 7200.11 ST31000333AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
-- (5X) ANTEC 120mm LED Tri-color Case Fans
-- (1X) COOLER MASTER 120mm Case Fan
