Cooling the Phenom II 720
Hi Guys
i want to know you're opinion's on Cooling the Phenom II TripleCore 720
what's the best cooler for this which one would cool it the best give me your opinions please price highest to lowest please
Thank you for you're time
9 answers Last reply
More about cooling phenom
  1. Um, this is an incredibly cool running CPU anyway. Mine runs at about 35C with just a decent fan.
  2. Try the XIGMATEK HDT-S1283. $36.99. Has my Phenom II 940 running at about 34 - 37 idle depending on the room temperature. If you get it from newegg before the end of april they include a free USB cable. (not related to the product but its a free 15ft cable, may come in handy sooner or later). It also will ship for free...
  3. I can tell you what I did and what temps I am getting.
    I did not use the stock thermal compound. I used Arctic Cooling MX-2 which is 6.99 $. Then, I simply put a MASSCOOL 80mm fan on top of the stock HSF. My CPU idles @ 30C and peaks @ 50C (under Prime 95). The cores idle @ 19C, and peak @ 32C.
    The fan costs 2 $ + shipping. You can buy 10 of them for 12.99 and pay no shipping.
    So everything ended up being 8.99 $. What do you think?
  4. XIGMATEK HDT-S1283 is a great cooler keeps my 720 x3 27 cel idle 37 cel full load o/c ed at 3.5 stock voltage
    http://www.microcenter.com/single_product_results.phtml?product_id=0288207
    in the top 10 coolers for the $ its a good value $29.99 $19.99 after rebate savings
  5. Heck, I have a fanless heatsink on my overclocked quad-core Xeon, and it does fine. 35C Idle and 60C load.
    Edit:
    Whoops, I'm click happy. Forgot to say it's the Zerotherm BTF95.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835887001
  6. ill be putting another 4870 hd radon into my new m4a79 delux, and 940 xquad core phenom. itll be a somewhat tight squeeze close to the cpu fan and heatsink, the 4870 is a very sweet card but it runs somewhat hot ,im running a stock cpu cooler now and havent oced yet, but if i need a cooler for the second card what is a good recomendation, any one done this yet? thanks james
  7. I talked about my experience in my previous post.
    A buddy of mine just bought a new system with a 4870, and he put a Zalman VF1000 on it, and it keeps it nice and chilly. I can't remember offhand what it lowered his temps to, but it was very significant. It comes highly recommended.
  9. Sycthe Mugen 2 is kewl.
CPUs Cooling Phenom Product
