Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Network settings problem? Cant change router with same settings
http://i44.tinypic.com/14v0dpl.png
Settings:
Router1:
eth2+eth3 = bridge1
eth1=WAN(Internet)
Bridge1= IP: 192.168.1.1/24
src-nat src address: 192.168.1.0/24, action:masquerade
routing: dst-address: 192.168.2.0/24 gateway: 192.168.1.2
dst-address: 192.168.3.0/24 gateway: 192.168.1.2
Router2:
Eth1 IP: 192.168.1.2/24
Gw: 192.168.1.1
routing: dst-address: 192.168.2.0/24 gateway: 192.168.2.2
dst-address: 192.168.3.0/24 gateway: 192.168.2.2
src-nat src address: 192.168.2.0/24 masquerade
src-nat src address: 192.168.3.0/24 masquerade
wlan1 in ap-bridge mode: IP: 192.168.2.1/24
On network 192.168.2.0/24 runs DHCP server giving devices connected to AP(wlan1) ip addresses(ip pool: 192.168.2.2-192.168.2.254, network: 192.168.2.0/24, gw: 192.168.2.1)
Router3:
wlan1 in station-mode, dhcp-client(gets ip dhcp lease: 192.168.2.2/24, gw:192.168.2.1)
eth1: IP: 192.168.3.1/24
I want to change router2, but other routers are still power on(must be), but the same settings in that I want to put on place of router2(just restored backup), but doesnt work, there is no firewall, na arp-only. I cant ping after change router1 neither router3, I tryed 2 devices, I tryed ros3, ros2. Router1 is running on ros 2.9.51, router2: 2.9.51, router2: 3.20.
Can you please help what can be wrong, I try this prety long, also I tryed to set router2 from beginning(after reset), I dont know what to do now.
Maybe some mistake in settings but I dont think.
Sponsored Links
Router1 makes QOS from internet and firewall, behind router3 are 3networks, and router 2 works as connection between router1 and router2 and makes traffic shaping for networks behind router3, maybe there should be better to change router2 in different mode, bridge, eoip tunel...what do you recommend?
Reply to rado3105
There are 1152 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
