Tom's Hardware > Forum > Motherboards & Memory > MSI-Microstar > [Solved] MSI 865PE Neo2 - won't power up
Forum Motherboards & Memory : MSI-Microstar - [Solved] MSI 865PE Neo2 - won't power up
Best answer from Mondoman.
System: MSI 865PE Neo2 with P4 2.6 800 MHz FSB, 1.5 gig RAM
The computer shut down without warning, and would not turn back on. I checked all of the connections (fine) however the only evidence of power when turning on the front power switch was a brief flash of the DVD light. I noted that the inside of the case was hot (apparently the kids had left it on for days on end). I replaced the generic 400W power supply with a 500W unit.
When I turn on the power supply power, the CPU and video card fans both twitch. When I turn on the power at the power switch on the front of the machine, they sometimes also twitch, but no other evidence of power is present.
I tried disconnecting each of the peripherals in orderto see if something was causing a drain, but nothing made any difference.
Is it the board, the CPU, or...?
Thanks!
Most likely the MB, but make sure you have tried clearing the CMOS before declaring it a loss.
Sponsored Links
Best answer
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
How do you clear the CMOS without powering up the computer? Thanks!
Reply to tomservo
You definitely do not want power connected when clearing the CMOS! It usually involves moving a jumper -- the procedure for your specific MB will be described in the MB manual.
Reply to Mondoman
Tried clearing the CMOS but nothing happened. Looks like she's dead. :(
Reply to tomservo
There are 1355 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
