Just got all the parts for my computer today. Installed everything including my Xigamatek HDT Cooler on my Q6600. Started the comp up checked the bios disabled the auto fan so the speed is the highest at all times. Then booted up and started running windows update. Core temps on all four cores seemed very high.
Ran the test using Core Temp
This is all pretty much on idle. I got this computer to play some games on but havent even dared to try it out.
Core Temp 1: 66
Core Temp 2: 58
Core Temp 3: 56
Core Temp 4: 57
They all vary a bit but I just dont know if thats right. The numbers are jumping up way too much. Could it be because the computer hasnt been running too long and it needs time to break in?
Thanks for the help.
I also applied the Arctic Silver Compund according to their website. Not using too much and not using too little.
Core Temp 1: 66
Core Temp 2: 58
Core Temp 3: 56
Core Temp 4: 57
