Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Need a recommendation on replacement motherboard
Forum Motherboards & Memory : General Motherboard - Need a recommendation on replacement motherboard
Hello,
I need a recommendation on replacement motherboard that will fit in to a Sony Vaio desktop Model VGC-RB52.
The specifations listed:
http://www3.dealtime.com/xPF-Sony- [...] MDM-XP-MCE
It had an Intel E210882 board with 2.8Ghz cpu, The Sony part number for the OEM board is 178930631 or 1-789-306-31
I was told a different board can be hard to find that will fit, there has to be something that will fit it's an ATX. I am looking for the board and CPU combo.
Tiger Direct said they had one (B693028) but was not sure the mounts would line up. It is also a smaller board http://www.tigerdirect.com/applica [...] ey=b693028
The original board is a 9 1/4 by a 9 1/4 I think.
Any thoughts?
Thanks
Ken
Sponsored Links
Newegg.com has a gigabyte g41 board with e5200 retail boxed cpu for $124.95 that would give you a better cpu and board. Any micro atx board should fit your sony case. The newegg combo deal is under "cpus and motherboards" subsection under cpus.
Reply to o1die
Thanks for the reply.
You don't by chance have the part number do, I was looking on there site and didn't see it.
Are you thinking the gigabyte g41 board is better then the Biostar G31-M7 TE Motherboard / CPU Bundle.
Thanks
Ken
Reply to krosloniec49426
There are 1108 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
