Let me preface my question that I'm not a gamer. I just want to make the machine run better with Adobe Illustrator, Photoshop, and Dreamweaver. It runs OK, but bogs down some, so I'm just looking to give it a boost. I have plenty of RAM, but only have the factory on-board graphics chip. It's a relatively low-end desktop. I don't want to upgrade the power supply, so am looking to get whatever improvement I can without overloading the system.
300W is not very much when it comes to powering a graphics card other than the integrated one. This one is minimum 300W, so you should be ok. It is very cheap ($40.00 after rebate). Just make sure your interface is right.
Thanks!
A video card won't usually speed up the performance of your system for 2D applications. (Actually Photoshop can make use of video cards.)
It would be a little helpful if you could post your system specs. We can make a better judgment to what your current system load is and what we think would be reasonable. Thanks.
i have a nvidia 9500gt it consumes very little power but it preforms well. it says 350 watts on the box, a good card for a 300 watt psu is hard to find
Message edited by jadavis1992 on 02-23-2009 at 09:07:50 PM
------------------------------I'm only 16 i cant afford this stuff
i need a job
Reply to jadavis1992
I vote for a 4650 it wont need extra power leads and will play the odd game if you wish pretty well, its a good HTPC card also.
As the others say your specs would help, i also doubt that its all down to th egraphics chip and am wondering about what CPU you have ? Newer incarnations of your aplications will no doubt need more power to run than older versions did.
Mactronix
