Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 9800GT Power Problem
This message keeps coming up whenever I start using programs that would require my graphics card to perform:
"The Nvidia system sentinel is reporting that Nvidia-powered graphics card is not receiving sufficient power.
To protect hardware from potential damage or causing a potential system lockup, the graphics processor has lowered its performance to a level that allows continued safe operations."
I am currently using:
VGA: Gigabyte nVidia Geforce 9800GT
PSU: Seasonic M12 600W http://www.seasonic.com.tw/pdf/dat [...] -500HM.pdf
Does anyone know what the problem may be?
Sponsored Links
if thats what it says, you have to asume thats the case. Your power supply isn't delivering the goods.
Some cards require more than 1 pci-e power connector to be pluged in (my 9800gtx does), make sure everything is connected correctly.
I had a 500watt psu that resulted in me getting that error a few weeks before it died. anyway you can try another psu ?
Reply to Lee-m
- 0 +
Seasonics are pretty good PSU's, but if the system says that you have a power problem, that's the first thing to check out.
The second thing would be the video card.
Reply to jsc
There are 1256 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
