Tom's Hardware > Forum > CPU & Components > Sound Cards > Front panel audio
Front panel audio
Forum CPU & Components : Sound Cards - Front panel audio
I have a Gigabyte G31M-ES2L motherboard and an Aerocool ExtremeEngine 3T case, using S.B. Audiology. I cannot get front panel jack to work. These are the pins coming from jacks: MIC Data, GND, MIC VCC (power), Ear R with an extended Ear R, and Ear L with an extended Ear L.
The manual shows HD front panel as MIC2-L, GND, MIC2-R, ACZ_Det, Line2-R, Faudio_JD, GND, Line2_L, Faudio_JD. For AC'97 front panel shows MIC, GND, MIC Power, Line Out R, Line Out L.
In the BIOS it shows ACZ, do I need to change it to AC'97? Is there something else I am not doing?
I am a female and this is my first build.....help. Thanks :o :hello:
Sponsored Links
Try changing it to AC'97 to check it, could be a faulty front panel if nothing worse.
Also, have to say...
First build, relevant
Female, who cares?
------------------------------ Antec 1200 -=- Corsair HX1000 -=- GA-X48-DQ6 -=- Q6600 @ 3.2 GHz -=- 8GB RAM @ 800 MHz CL4 -=- 4870X2 800/1000 -=- 2x 500GB 7.2k RPM -=- 150GB 10k RPM
Reply to Kraynor
I had the same problem. try going into the sound control panel and find the Audio I/O setup/settings. In there you should find the option to "Disable front panel jack detection" or something like that. Thats how mine is set up in order to work. The only thing is that both front and rear outputs will have sound. You will have to manually turn down the computer speakers but it works great. Let me know if this helps.
Reply to jmcbride1983
There are 521 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
