Power Supply Problem perhaps?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power Supply Problem perhaps?
Just received a BFG TECH 550LS power supply. It has 550 watts and Active PFC. Is it normal for a PSU with ACTIVE PFC/Thermal control to have a 4-5 second lag from power up before the FAN starts working? And if I power it off the FAN still spins for a few seconds too. The BFG PSU is not really quiet, it has a low humming sound. Also the first time I turned the unit on - there was this weird buzzing sound that seems like the FAN is having a hard time spinning (it worked after a 3-4 seconds). Is this a defective unit? or is the auto temp control for the fan causing this?
Sponsored Links
AFAIK, BFG's 550 series automatically controls the speed of its fan. Here's what the marketese on NewEgg says:
Quote :
These units deliver higher efficiency with integrated protection circuitry for a more stable and reliable source of power. [strong]The cooling fan varies speed according to load to run as efficiently and quietly as possible.[/strong] Easy installation and a full range of connectors makes this a sure hit with gamers and computer enthusiasts alike. [emphasis mine]
Reply to r_manic
the only people who would know that would be BFG themselves so give them a call. i am sure they have a tech support hotline
Reply to captaincharisma
Thanks. yes, FAN is defective. I contacted them and told me to exchange it. I will not exchange it with the same of course, I should have bought a Corsair PSU.
Reply to 45mapper
How long will the exchange take? And what PSU will you get as a replacement? Thanks for sharing what happened btw.
Reply to r_manic
I bought it from DELL, I told them it was defective and they issued me a UPS shipping return label for free (if defective)
Anyhow, I just read somewhere that starting a high efficiency PSU with no load will cause some problems, I was testing it last night with the paperclip. I will install my mobo, video card and AMD Kuma to see if the problem goes away. I'm going to give it one more shot. The power supply is fine it's just the PSU fan that is acting up (I lodge a pencil to stop the fan and the noise went away to eliminate any other causes)
Reply to 45mapper
Ok, heres the update,. just bought a CORSAIR 550VX for $40 used (thru craigslist). Went home, tried the BFG PSU with mobo/cpu + video card installed and it still has the same problem, the fan makes a whining sound and it does not start right away. When it does start there is a clicking noise, although computer runs ok.
Then I installed the CORSAIR 550VX, it is as quiet as a sleeping baby! I immediately boxed the BFG piece of ^&%* to be returned. Kinda blessing in disguise, got the 550VX for a good deal.
Reply to 45mapper
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply Problem perhaps?
There are 601 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
