i have now one Radeon 3850 im wanting to run some games at a higher setting now i can buy one 3870 for 100ish and run the 2 cars in x fire or dump my card and get one 4850.
the 3850 can crossfire with the 3870 http://game.amd.com/us-en/content/ [...] _chart.jpg im looking to spend 100 ish bucks so cross fire with the one card i have and a new one or get the 4850 will the cross fire out preform the 4850
the higher the resolution the better but im not gaming on a 30 in LCD might be nice one day tho
So I think you may be reading that chart wrong. It is not RECOMMENDED that you put a 3850 and 3870 in crossfire because the chipset may not support it. The combinations that are supported (recommended) have a dot in the middle of the square.
I read this to mean you might be able to crossfire an HD3850 and a hd3870, but the current chipsets do not support such a configuration. I have heard of folks who have had trouble with same cards but diffrent memory (one with 256MB, one 512MB, etc.)
Dual graphics cards is still tricky technology, and you may buy that 3870 and find you can't crossfire it.
Go with the 4850, you dont get any dual card complications it wont matter what your chipset is to support it and its a very good card uin its own right. Sell of your own card and you have a quite cheap very decent GPU
First, you can CF those cards. The 3870 will basically turn itself into a 3850, and you will have the power of two 3850s in CF. This however pales to the power of the 4850, more so if you enable AA/AF. Dump the 3850 on CL/Ebay for $50, and buy the 4850.
------------------------------The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
Forgot to mention, the reason why you don't want to run CF is because you have the P35 chipset. If you have two PCIe slots, the second one doesn't run even with the first one. My P35 does have two slots, but they are 16x/4x. I believe it was toms that ran a review of CF on such a setup, and it constantly turned in LOWER scores then a single card. Unless you have an 8x/8x setup, just stay with a single card.
Always a DEMON!
Reply to 4745454b
Not only is the res needed, but we need to know what types of games he plays as well. RPG/RTS games don't (usually) need a lot of GPU power. If his idea of gaming is playing WoW for 6 hours then any x2 card is overkill.
Assuming he isn't using anything higher then a 22" monitor and doesn't demand the highest settings, then the 4850 is fine. I'd probably move to the 4870 512MB before getting the 4850 1GB. The extra horsepower is probably needed more then the extra memory.
Always a DEMON!
Reply to 4745454b
Another option is to wait until April for the HD4890. There is going to be a 512MB and a 1GB version. even if this card itself is overkill, the price of the 4870 will drop. I have read that the added clock speed of the 4890 is enough to give a 25-30% improvement on the 4870
------------------------------Q6600 @ 3.0GHz | Zalman CNPS9700-NT Titanium Cooler | GA-EP45-UD3P | Sapphire HD4870 1GB | 4GB (2 x 2GB) OCZ PC2-8500C5 1066MHz DDR2 |OCZ GameXstream 600W |
Reply to peaks
To be honest this isn't a great time to think about upgrading your ATI - given the 4890 is supposed to be out in a couple of months. Regardless of whether you're interested in that particular card, it will push prices of the others down
1280 x 1024 is the res and price range 100 up too 160 so ill just go wate till the new one comes out and then buy the 4850 or unless the 4870 drops way down too then ill get that thank you guys so much
yea both the 4850 and 4870 cards would be fine at that res
Although will you ever be upgrading your monitor to a higher res? Both the 3850 CF and the 3870 CF bench higher at 12x10. Possible because the the other cards optimal performance is at 16x10.
Just had a look at general prices on newegg and they are around the same.
So I would probably say that the 3870 CF would be a better option for you res. Nut in terms of bang for buck and covering all potential upgrades you might wanna stick with the 4850/4870.
lol I think I am complicating things now....
Reply to peaks
Don't bother with another 3870 - try and avoid a crossfire rig if you can, especially as your MOBO wont run both at full speed. In your case a 4830 would be the gaming choice, with the 4850 being the enthusiast option, if you can afford it.
