Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Need help choosing replacement motherboard
Forum Motherboards & Memory : General Motherboard - Need help choosing replacement motherboard
Hi all
I basically need to get a replacement motherboard and was wondering what would be the best option with a max price of around £70. I have heard that you can purchase the best stuff to plug into it but the motherboard could slow things down so I want to ensure I don't do this with any of my existing hardware.
The replacement will need to house the following;
Pentium D Dual Core 3.4Ghz
2x 2GB Sticks of DDR2 RAM (240-pin)
At least one IDE port and one SATA port.
PCI Expressx16 slot (for a GTS250 1GB)
Power Supply is a 20/24 pin 580W
Also, my current one is a Micro ATX board but there does seem to be a couple of inches space beneath it in the case although I'm not sure if this would allow for a normal sized board...
Ideally, it would need to be purchasable in a PC World but will order online of the choice/cost is too poor.
Many thanks in advance..
Sponsored Links
Gigabyte and Asus have the best reputations IMHO. I may be hard to find a current MB that supports a Pentium D, as those CPUs have not been sold for a few years now. Note that the "Pentium D" is a completely different CPU than the current "Pentium Dual Core" CPU series. The latter are just versions of the Core2Duo line.
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
The asus P5KPL-cm lists support for your 3.4 p4 dual core. It's a g31 chipset micro atx board, so it should be easy to find and inexpensive.
Message edited by o1die on 06-26-2009 at 02:59:24 PM
Reply to o1die
Thanks, had a look and it looks good. I'll try and get it in.
Reply to Sokoprok
All ordered now, seemed to be the best of the options and for less than I was hoping to pay anyway. Only downside is I have to wait until Tuesday for delivery. PC World are sooo overpriced and the choice is unbelievable small.
Same goes for Maplins. The didn't even sell a compatible Intel motherboard, they were all Athlons.
Thanks again.
Reply to Sokoprok
most LGA775 boards do, athrough I bet they wouldn't like it much ;)
------------------------------ Q9550 3.8Ghz//ramapge formular//OCZ reaper 4Gb// 3 seagate HDDs// sapphire HD4870 512 // CM HAF 932
Reply to AMG
There are 1133 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
