I just built a new i7 machine with X58 Pro and Patriott DDR3 memory (total 6 GB, 2GB x 3). It is very, very unstable unless I load only one stick of memory. Any ideas? Bad Mobo? Memory tests are all okay.
The first thing I'd recommend is to manually set all voltatges and timings on the Bios, rather than depend on the Auto settings.
------------------------------Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
