Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > No Cmos Battery? STill working
Hey guys,
My computer still in working shape even without the CMOS battery. Has that ever happened to anyone and what the effects of not having the CMOS battery in? I was wondering if it would be bad to not have one at all and what, if any problems it would cause.
Sponsored Links
It will lose all settings, including time as soon as your power off the PSU or you have a power failure. Other than that, nothing to worry about. Can't you afford the cost of a new battery?
Reply to GhislainG
I can, but my graphic card is so big it blocks the cmos battery slot x-x
Reply to xeresium
Then how did the battery escape lol? Hmmmm . . . maybe if you take the vid card out, then put a new battery in, then put the vid card back in . . . yeah, that's the ticket.
Sheesh!
Reply to Twoboxer
- 0 +
bios will reset to defaults ever time you reboot. but seeing as most people run default settings anyway the only issue would be the clock.
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
- 0 +
Sheesh!
But that's just so much work, and he has to do it so very often.
Reply to jsc
- 0 +
LOL what yeah it will still work just don't power down the system LMAO
take the card out and replace the batt or is that too hard :P
------------------------------ Q9550 3.8Ghz//ramapge formular//OCZ reaper 4Gb// 3 seagate HDDs// sapphire HD4870 512 // CM HAF 932
Reply to AMG
There are 677 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
