So im thining of upgrading my gfx card, hd2600xt to something a bit newer. My psu is unbranded 460w. Are the 4670 cards that good? I would like to stick with ati as much as possible. Any suggestions would be graet. Some specs of my comp:
P4 3.4 ht
3gigs cosair ddr2
320gig sata seagate 7200rpm
160gig sata seagate 7200rpm
hd 2600xt 256mb pci-e
xp home ( would like to go to vista for dx10)
I know the cpu isnt that great, but its a dell and well you really cant upgrade their cpu's Im not quite ready to start building comps again, so till then, just like a nice upgrade. I pretty sure that the 2600xt uses a seperate power plug (stock card was a 6800gt pci-e). But the more I think about it, it might just get the watts of off the slot. The 4870 cards will be out of my reach to get and probably the cpu be a bottleneck.
Thank you in advance!
P4 3.4 ht
3gigs cosair ddr2
