Hi, thanks for reading. Tom's has helped me immensely while building my new system and in the end I finally encountered a nitpicky problem that I can't find an answer for...
I'm using the Geforce 8200 onboard GPU that is on my XFX mobo.
I have it connected to my Westinghouse 32" SK32XXX HDTV via HDMI.
I CANNOT set a screen resolution that will fit the screen correctly; The desktop (taskbar, icons etc.) is too large for the screen.
I originally had the HDTV connected via VGA and the resolution would auto-adjust to 1024-768 and display perfectly.
I switched to HDMI and put the VGA on an old Dell CRT monitor to use the dualview feature.
I've checked all the settings on my TV and also gone through each of the resolutions and none of them will fit the screen correctly.
I'm assuming it's an issue with the HDMI output and the settings there. Nview picked a 1080i output for the TV (which is it's max) and that's when the problem began.
