CPU water Cooling
ok im into purchasing a water cooling unit for my i7
what brand should i be investing into
More about : cpu water cooling
You need to be seriously involved in WC to make it work. It is not like buying a new component and installing it in an evening.
If you like researching topics and building out computers, then click here to get started: Watercooling-read-first
Related ressources
- CPU /GPU Water Cooling first timer? (: - Forum
- Do water cooling hv a great impact on ability to OC( CPU & GPU) ? - Forum
- TEC/Peltier CPU Water Cooling - Forum
- AM3+ board and CPU with AM3 water cooling - Forum
- Water Cooling My CPU - Forum
I've been WC'ing for almost 6 years now, and I love it, but I think there are a lot of people that don't know what they are getting into...and only to say 'look, I water cool'. Don't get me wrong, it's a lot of fun if you like doing things out of the ordinary and want to learn what works and what doesn't. However, if you are only looking for that 'gimmicky-ness', i'd suggest going with a good air cooler.
OK, so now that the definition of minimum liquid cooling is cleared up, put the H50 out of your mind for your i7. Your CPU produces too much heat for that little thing.
Hey rubix, could you evaluate this for starters?
Thermatake P500 Water Pump for $50
Swiftech MCRes-Micro R2 SSF Hi-Flow Acrylic Reservoir for $23
Swiftech Apogee XT Intel Water Block for $80
Swiftech MCR220-QP Extreme Duty Dual 120mm Radiator for $48
Fesser Active UV Hose 3/8" ID 1/2" OD Anti-Kink Tubing for $20
Thermaltake BigWater UV Sensitive Coolant for $14
Total is $235, and a little bit more for tax and connectors.
gordon_81 said:
yes i agree, just go for a decent air cooler like the noctua NH-D14 or thermalright venemous x, they both out perform the corsair h50 water cooling option and you dont have to have all the hassles that come with water cooling, but then you have to have a pretty big case as the noctua is 6,2 inchesSorry i have been busy i did research on the (thermalright venemous x) looks impressive and cooling as well is great
Sad side is my brother already got me a corsair H50-1 water cooling so i dont know what to do now loli have a CoolerMaster Sniper Case
eloric said:
Your CPU produces too much heat for that little thing. Having used the H50 with P/P fans on an overclocked I7-860 ( @ 3.8 ), I7-930 ( @ 4.0 ) I7-965 ( @ 4.0 ) and I7-980x ( @ 4.0 ) I can tell you that you are wrong.
You wouldn't be able to break any overclocking records using it, but when properly configured it does just fine for moderate overclocking of the I7's.
I'm not rubix, but as to your shopping list, MC has the Danger Den CPX-1 pump for a couple of dollars less ( or the Jingway DP600, same pump with higher flow and pressure ratings ).
Stay away from bottled coolants, distilled water and a biocide are all you need, should cost you around half of what the bottled coolant does and will refill your system without having to buy another bottle of premix ( a $3 bottle of PTNuke should last for years, won't find it at MC though ).
eloric said:
OK, so now that the definition of minimum liquid cooling is cleared up, put the H50 out of your mind for your i7. Your CPU produces too much heat for that little thing. Hey rubix, could you evaluate this for starters?
Drop the coolant. Use distilled water only with some biocide or PTnuke. As for the pump, I'm not sure, haven't used it before. Looks like a flow rate of 500L/h, which is ok. The MCP655 is rated at 1200L/h, and the MCP355 at about 455L/h, if that is any comparison. If you want outright brute power and flow, the MCP655 is the best bet until you get into the aquarium pump arena. Note though, your components you have selected indicate a 3/8" tubing size; moving to the MCP655 will put you into the more common (and widely accepted as standard) 1/2" ID tubing size, unless you use fittings to reduce the tubing size.
eloric said:
To the user of the dell: I defer to your actual experience, but have one question: how the 'ell do you overclock a dell?
You're either lucky enough to get one that software overclocking programs will work with or foolish enough to spend the money on one of the higher end systems that had the ability.
eloric said:
To emmerichem: If you already have the H50, then use it, case closed!To the user of the dell: I defer to your actual experience, but have one question: how the 'ell do you overclock a dell?
To rubix: $30 more for the MCP655 looks like a good bet. Also, appreciate the advice on the tubing.
Yeah well im gonna go ahead and use H50
Thanks for the support Bro. oh i dont know about dell systems
i have always built my own systems lol
saint19 said:
^According with that.If u aren't worried about the price why u don't wait for the H70 that performs much better that the H50?
That sounds like a good temptation
well my brother baught it for me as a good gesture
so i dont want to throw it in his face you know in a good way
so why not just give it a run besides im not so power hungry
im more into graphic modeling and animation
Could this problem be solved with just these coolers:
CoolIT SYSTEMS Domino A.L.C Advanced Liquid Cooling
or
CoolIT SYSTEMS ECO-R120 Advanced Liquid Cooling (ALC)
They are less than $70 each.
Ciao!
or
Ciao!
Related ressources:
- ForumWatercooling-read-first
- ForumIs CPU Water Cooling Worth it?
- ForumAMD FX-8120, asus 990fx v2.0 board just installed, water cooling on cpu and the
- ForumWater Cooling My CPU
- Forum$2,000 gaming build with custom cpu water cooling loop
- ForumCpu w/ water cooling or..
- ForumUpgarding cpu , need help with water /air cooling !
- ForumNeed help on a CPU loop water cooling !
- ForumCpu vs video card water cooling
- ForumSilent CPU water cooling
- ForumWater or Air cooling for CPU .
- ForumQuietest possible VGA/ CPU internal water cooling
- ForumFANLESS cpu water cooling
- ForumBest $53 Heatsinks
- Forum[Solved] How long and how reliable is a H50 water cooling unit from Corsair?
- More resources
Read discussions in other Overclocking categories
I see the H50 only comes with 1 fan what a joke lol
