1 I have a bad IDE port on my Asus M3A78-T. RMA is sending same but new broad. MY question is do i have to load OS again, or can i just swap it out?
2 I can't change my resolution higher than 1280*1024, do to my moniter. My card will go much higher. How can i get my resolution higher to get max performance?
Windows 7
AMD X2 7850
Arctic cooling Frezzer 64
Asus M3A78-T
G.Skill 2x2gb 1066
Asus Radeon 4850
Coolmaster 500w
Seagate 500Gb
Antec 900
Sharp 19" 172a
yea you can switch out motherboards like that, i had 2 of the same motherboards once, had one laying around and the one i was using went bad so i just used the one that was laying around and didnt have to reinstall the os or anything
for your other question you would have to get a monitor that supports a higher resolution
that about covers it
------------------------------E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
