Hi
I am building a system for my parents. It is a micro-atx system with no stand alone video card. The case comes with a 585 Watt power supply and I would like to know if a 200 Watt, 400VA UPS will be work?? Are they supposed to have the same watts? Does it matter?? All I need is something to keep the system on for long enough so my parents can shut it down in case of a power surge or power outage. Thanks for your help!
What's more important is what is the 585W PSU powering? If it's a system that requires 300W, then no problem. What's in their system and what display are they using? If total power is less than 400W, then you're fine, but I would automate the power down instead of leaving it up to them. They might not be in front of the computer when a power failure occurs.
Thank you for the reply
Not sure how much power is required. Here are the specs
CPU: Core2 Duo Intel e6600 @2.4 GHZ
GPU: On-board
SOUND: On-board
MEMORY: 4GB (2x2GB) DDR2 800 by G.Skill
PS: 585 Watt
HDD: SSD 32 GB by Kingston
+ keyboard, mouse, 2.1 speakers
Anything else you need?
Message edited by keczapifrytki on 04-30-2009 at 09:38:26 PM
It won't run for long. Configure it to shutdown after 1 minute of power outage. I presume they have an LCD and not a CRT monitor because it definitely isn't powerful enough for the system and a CRT monitor.
