G
Guest
Guest
hey guys I have an i7 930 overclocked at 4ghz (using the Corsair H50 Water Cooler kit) with 1.344V, bus speed 200mhz with cpu ratio at 20, RAM is set at 1600mhz with 1.65v and the motherboard is an AsRock x58 extreme motherboard. My CPU seems to runnning stable with all of this at 4ghz however I'm a bit concerned about the temps I'm getting when I stress it with Linx, as it reaches 94 degrees celcius (201 degrees fahrenheit). Also this is the first time I've overclocked a CPU before so any advice that would help me get the temps below the 90 degree mark while its stable would be appreciated .
Thank you
Thank you
