I received the following error after running System Mechanic...." Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk. Check boot path and disk hardware. Please check the Windows documentation about hardware disk configuration and your hardware reference manuals for additional information". Here is a list (in order) of what has been done to solve issue.
1. Attempted to use Dell recovery console, but may not have done correct.
2. Tried a fresh install (w/o format)...looked like it loaded fine, but at end, when it says press key to boot into windows, I got same error message.
3. Tried formatting drive, then re-installing windows from scratch...still got error.
During this, i did have to change BIOS to boot from cd drive, as far as I know It wont boot from either selection. Did I miss something here? I suspect a corrupt boot path, but if I can't get past the error message I have no way of telling.
Below are my specs, and ty in advance for any help.
OS- XP
Dell Dimension E310
OS- XP
Dell Dimension E310
