Tom's Hardware > Forum > Motherboards & Memory > Memory > Will a brand difference in RAM sticks cause problem in my system?
Forum Motherboards & Memory : Memory - Will a brand difference in RAM sticks cause problem in my system?
Greetings to everyone :hello:
I was about to upgrade my system from 2gb's to 6gb's of RAM when this question came to my mind, will there be a problem if I install 2 gb's sticks of ADATA Gaming Series alongside a 2gb's Kingston's stick?
All sticks are DDR2 800 (PC2 6400), with a slight voltage difference, while Kingston's work at 1.8V the ADATA's say to run at 1.9V~2.1V.
These are the models:
http://www.thinkcomputers.org/index.php?x=reviews&id=796
http://www.pcenlinea.com/mp/60072.html
As you can see the ADATA's have heat sinks while my Kingston don't, and also, can a 600w PSU handle well the 6gb's without issues?
Thanks in advance
.C.
Sponsored Links
If I understand this correctly, you now have 1-2gig Kingston memory stick?
You are going to install 2 x2gig more sticks? You do understand that DDR and DDR2 memory should be installed in pairs, right? It will not run in dual channel mode if it is not installed in identical pairs. So, if this is the configuration you have, pull the Kingston stick and give it to someone else who only has a single 2 gig stick. Install the 4 gig of Adata, and be happy. You'll never need more than 4 gig anyway.
If you have 2 x1gig sticks of Kingston, then you are good. And yes, the Adata should work in dual channel mode along side the 2 sticks you already have running in dual channel mode.
The system may not boot when you install the Adata due to too low of voltage.
If it doesn't, simply go into the BIOS and raise the voltage until you get to the point it will boot with the Adata, then raise it another .01~.02 volts to ensure it is stable.
Your PSU is no problem.
Message edited by jitpublisher on 06-29-2009 at 02:57:08 PM
Reply to jitpublisher
- 0 +
Mm... didn't knew about the logic of RAM, bloody noob I am.
I have a single 2gb's Kingston stick installed, so I'll take it out and keep the pair of ADATA's sticks.
Thanks so much for the advise jitpublisher
...So, will there never be a day when games ask for more than 4gb's of RAM?
.C.
Reply to CefVil
Its so cheap, just buy a 2x2gb kit and sell your old sticks. 4gb is plenty.
------------------------------ P965/Q6700@3.2 8MB HD4850 OC Edition
4GB Corsair XMS 800
Vista64/Win7
Fatality 550w/Antec 300
Reply to zipzoomflyhigh
There are 483 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
