System Tray is missing Volume Icon (and no system sounds)
have no sound or volume icon in the system tray
1 answer Last reply
More about system tray missing volume icon system sounds
  1. Go to the control panel. Double click on "sounds and audio devices", check the box that says place volume icon on the task bar, then click the ok button.
Configuration Windows XP
