I recently bought a GTX 295 and I only have a 20 inch monitor at the moment. Im looking for a 1920 X 1200 screen .Which of these two monitors do you recommend
The
Samsung t260hd - 26 inch $450
or
Samsung 2443BWX - 24 inch $400
My budget is capped at around 450 if you guys recommend anything else.
I want to get a monitor at a local store just in case there is a problem it is easier to return. That is why i have those two from Best buy and Fry's Electronics. I know there are a ton of better monitors but from those 2 which is best?
