Tom's Hardware > Forum > Motherboards & Memory > Chipsets & Bios > Biostar TA790GXB problem
Forum Motherboards & Memory : Chipsets & Bios - Biostar TA790GXB problem
Hi everyone, I made the mistake in buying a a low cost Biostar TA790GXB Motherboard and paired it up with a AMD Phenom II 940. But sadly, I am not able to get my GTX285 to function with this motherboard. The video card was working fine with my previous setup. I made sure to connect it properly, I also have the latest BIOS. I have also toyed around with the bios options several times and still no progress. If anyone has a similar setup and knows how to solve this please help. I'm not to familiar with Biostars bios configurations, so i'm hoping it's something wrong with the settings that way i don't have to return everything all together.
Sponsored Links
Hey 10sion, mind providing more details? What do you mean by not functioning properly? It runs too slow? It won't display anything?
Reply to MomoCC
There shouldn't be a problem just because it is a biostar. What power supply do you have, and was it also in your previous setup ?
when you toyed with the bios setups was the card installed or did you use onboard video ?
Message edited by royalcrown on 07-02-2009 at 05:27:52 AM
------------------------------ E8500,GA-EP45-UD3R, 8 GIG MUSHKIN, XFX 4890 , ASUS 22", WD 640 X 2, CM 532, CM 650TX
Reply to royalcrown
There are 554 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
