Alright, well i posted in new system build earlier and managed to fix my problem with my K9A2 Platinum by putting ram in slot 2 and 4 on bootup.... and it booted up. Problem is, in that config it runs in single channel mode. I have a Xigmatek Dark Knight cooler that blocks RAM slot 1. I tried booting with the RAM in slots 3 and 4, but it wouldn't boot. So, is there a BIOS update that would enable it to let me use only slot 3 and 4 or do i need to buy a new cooler?
I'm not having any problems running the memory at 1066, the only problem is that it's single channel. I tried using slot 2 and 3 as well, which wouldn't boot (for some reason). \
System:
Phenom II 940
MSI K9A2 Platinum
PC Power and Cooling 750 Silencer
Corsair Dominator 1066 2x2gb
Radeon HD4870
If nothing is possible in fixing it, I will remove the cooler and replace it with the stock one for now. Does anyone know of a cooler that wont' block ram slot 1?
System:
Phenom II 940
MSI K9A2 Platinum
Radeon HD4870
