Tom's Hardware > Forum > Graphic & Displays > Nvidia > SLI XFX 9800GTX+ Problems
Forum Graphic & Displays : Nvidia - SLI XFX 9800GTX+ Problems
When SLI is activated, most games show artifacts and/or begin to lag after a while. Without SLI everything's fine. Also, if I leave the fans on auto control they quickly go up to around 70-80%, which is incredibly loud. If I set the fans to 40%, idle temperatures are at around 60 degrees, which I guess is a bit high. Under load, with the fan set to 55-60%, the temperatures go up to around 80 degrees. That is a bit high, I guess, but it's not enough to cause problems, right?
I've tried switching the graphics cards place but it had no effect.
Also, in 3DMark06 I get 15400, should I get more than that?
I have 2 XFX9800GTX+, Asus P5N-T Deluxe and an e6750 overclocked to 3.2GHz.
Edit: PSU is Corsair 750W.
Message edited by nehacoo on 02-27-2009 at 11:34:20 PM
Sponsored Links
not sure about the SLi problem but with the temp try improving airflow into your machine, mine idles at 49 give or take a few on 40%.
Reply to Rain1406
There are 758 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
