Try setting your timings to 5-5-5-15 manually in the bios. Use cpu-z to check your timings while in windows.
With these timings, try bumping your voltage to 2.0 and setting your memory to 667 if you want to overclock. Then use cpu-z again to check the results. You can disable the eist (speedstep) setting in the bios while overclocking.
