Help! Need 8pin mod.
Forum Motherboards & Memory : General Motherboard - Help! Need 8pin mod.
Hey.. I have no car till Monday. So I bought this new mobo EP45-UD3P. That thing needs a atx 8 pin mobo adaptor from the PSU. But my PSU is a first gen PSU for crossfire but it only has a 6 pin plug, not the 8 pin. This is the adaptor that I need...
http://ep.yimg.com/ip/I/pcpartscollection_2057_56754754
and I found this mod for a vid card but I thnk the layout might be different than the mobo plug. But comes close but I wont risk it.
http://www.isyougeekedup.com/how-t [...] ideo-card/
So does anyone have a link in how to make a 8pin otu of a 6pin or 4 pin? Im stuck home till Monday And I wanna game sooo badddd!
Sponsored Links
http://ep.yimg.com/ip/I/pcpartscol [...] 7_56754754
Wait... is this connector mod for your motherboard or your video card?
Reply to g3force
Do you realize there is a difference between the Mobo 8 pin plug and the PCIe 8 pin plug? They are notched differently, they are not interchangable. What you need is a new PSU, one that has the proper plugs.
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
- 0 +
It might be possible to use the 4 pin ATX 12v connector in the 8 pin EPS connector, but I've only done this with a Celeron 430. I have no idea if it would work with a processor with a higher TDP.
Reply to g3force
- 0 +
I need the 8pin for the motherboard. Sorry... I have the 4pin but need the 8pin. I do have the PCI express wghich is the 6 pin.... Did you guys see the picture of the adaptor that i need? I need that and it will work but I have no ride. SO i was ondering is anyone has modded anything similar to it,.
Reply to exil3d
- 0 +
http://www.crazypc.com/images/cables/8pin/ad202big.jpg
Heres another pic of what I need. Anyne evr modded anythingt o resemble this?
Reply to exil3d
Without an actual 8 pin connector, your hosed.
Always a DEMON!
Reply to 4745454b
- 0 +
Not to worry.
Download and read the mobo installation manual. The 2x4 connector is recommended if you will be using a 130w extreme edition cpu.
Otherwise, the connector is compatible with the normal 2x2 connector which you have.
Reply to geofelt
- 0 +
geofelt wrote :
Not to worry.
Can you explain a bit more? I have the q6600 cpu. Is that a 130w extreme edition? Whats the extreme edition that you talk about? CPU?PSU?MOBO?
Reply to exil3d
- 0 +
Ok.. I think you meant the CPU. It loks like the q6600 quad core is not the extreme ... i think. But I have another Idea.... what if I get another plug 4pin from a spare psu and splice it and solder it to the actual 4 pin of my existing PSU. The I would have a total of 8 pin. WOuld sharing the same line be a big deal?
Reply to exil3d
- 0 +
The intel extreme edition cpu's should be something like a QX6800:
http://www.newegg.com/product/prod [...] 6819115021
I think you are fine with a q6600. I don't know about overclocking though.
You can buy an adapter like this which should work if you are worried:
http://www.pchcables.com/atx4pinto8pi.html
Reply to geofelt
- 0 +
Thanks geofelt. I saw several of those around the net trying to figure if i can make it happen. Looks like thats the best solutin besides buying another pricey psu. Anyways.. I went ahead and built it and plugged int he 4pin to the right side where it shows for regular cpu instead of the extreme version. And it booted. I do want to overclock it to 3ghz so that might be a issue. Ill find out later.
Another important question for you tech gurus.
Look at this adpeter geofelt showed. http://ep.yimg.com/ip/I/pchcables_2061_1769681
And look at this adaptor. http://kablammo.strongerthandeath.com/wp-content/uploads/2009/04/adapter.JPG
One is just a 12v line sharing the same line while the other is split between 2 12v lines. Would it matter? What would be the best choice? Wouldnt the 2 12v lines feeding into 1 8pin plug cause somewhat of a volt fluctuation? Or while the 1 8pin line split into 1 12v line have a too much of a draw of current to make the system a bit unstable?
Reply to exil3d
- 0 +
I speculate that it does not matter. I think it is more of a matter where the power goes TO, 8 pins vs. 4, instead of where the power comes from.
Reply to geofelt
- 0 +
overshocked wrote :
you cant wait 2 days, seriusly?
ehheheheh.. extreme geek here. Well.. its still running. maybe it will work with the 4 pin afterall. The system has resseted after a feww app were launched. (bf2) But it might be because I have not formatted my pc and running on a old system XP setyup. I will format. Thxs evryone for your guidance.
Reply to exil3d
- 0 +
Well.. so you guys just know. My PC has been running fine with the 4 pin. I havent overclocked yet but in stock.. its running just fine. Im in crossfire too.
Reply to exil3d
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Help! Need 8pin mod.
There are 1218 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
