New System Being Built
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - New System Being Built
Okay here's what I'm wanting to do...
I got the following hardware:
MOBO:
http://www.newegg.com/Product/Prod [...] 6813131361
CPU:
http://www.newegg.com/Product/Prod [...] 6819103471
RAM:
http://www.newegg.com/Product/Prod [...] 6820227289
GPU:
2x nVidia GeForce 7800 GT OC (will upgrade soon)
PSU:
Okia 600W Power Supply (will upgrade soon)
I am trying to decide on either SLi or Crossfire. I love nVidia cards, but I'm starting to like some of the ATi cards starting to come out. I am curious to know what everyone thinks. I also would like to know the PSU requirements for going dual, triple, or quad SLi or Crossfire.
Sponsored Links
That motherboard only supports Crossfire - you shouldn't be able to run SLi on it! If that's what you have, spend your budget on 48X0 series cards, and try to keep the total number of discrete GPUs to a minimum.
That PSU should be good for up to two 4850s. You *should* be able to handle two 4870s or a 4870 X2, but I wouldn't run it. I'd try and get 800-850W, but that might be overkill.
------------------------------ Phenom II X2 unlocked to four cores @ 3.8gHz,1.45V. 4GB DDR3-1600 Gigabyte 785g ATi Radeon HD4870 1GB
Run Folding@Home! Support Toms Hardware Guide, Team 40051!
CPU Buyer's Guide
Reply to smithereen
in the context of "discrete" GPUs what do you mean?
Reply to jadamselectroncis
also, the mobo listed DOES support SLi for a lot of people I know have been doing SLi for a while now with it
Neat. I never knew that.
I mean try and keep the gpu cores to a minimum.
CPU Buyer's Guide
Reply to smithereen
I thought having more graphics cards would make my video gaming better... I am sorry but it's been nearly 2 years since i built a computer so this new technology is something i'm trying to familiarize with
by the way, i'm thinking about going back to ATi anyway. the last ATi i used was the ATi Radeon 9800 Pro (hahaha) and I hated it, but I'm hearing good things about the ATi now (even tho I absolutely love nVidia)
Message edited by jadamselectroncis on 05-03-2009 at 04:34:04 AM
It would! But one $300 card usually beats two $150 cards, largely because support for SLi and Crossfire is often sketchy, and usually nonexistant for 3- and 4-card systems, although it's getting better. Try and spend your budget on one or two cards. 4870s and 4890s look real good right now.
CPU Buyer's Guide
Reply to smithereen
okay cool i really appreciate the information
Glad I could help. Let us know if you have any other questions.
CPU Buyer's Guide
Reply to smithereen
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > New System Being Built
There are 716 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
